Old 02-27-2015, 01:21 PM   #11 (permalink)
It might be interesting to hinge the top of the bulkhead to the tonneau in such a way that the tonneau could be flipped all the way to the front, thus enclosing the front instead of the back. (Assuming the bulkhead remains stationary.) Worse aero, but might be useful depending on the cargo you are carrying (it's hard to get to the front open area to load and unload stuff with the half tonneau in the usual position).
My half tonneau is smaller because I have a Rambox, and can be slid out of the Rambox rails, flipped over and laid on the floor in case I need the whole box. I did find however that it expanded enough when it got wet this winter, that I was no longer able to slide it into the rails. There's always something...
Old 02-27-2015, 01:56 PM   #12 (permalink)
Grogu - '12 Toyota Tacoma Base regular cab 4x4
90 day: 23.3 mpg (US)
I'm going to use a piece of plywood with some small holes cut for 4 c clamps. Then I can just undo the clamps and lay it on the bed floor. It will sit on top of the bed rails and have beveled edges. I'll probably seal it up pretty good with some marine epoxy I have then paint it.
