Old 06-18-2008, 08:58 AM   #1 (permalink)
Is it harm to race the cool engine ?
My car was left in the car park for a few days. This morning, I started the engine with the automatic transmission selector lever in the 'Neutral' position, the accelerating pedal was accidentally pressed all the way down for few seconds. What is the bad effect on the engine and other parts of the car?
Chow
Thanks in advance.
Old 06-18-2008, 09:20 AM   #2 (permalink)
Bicycle Junky
NoCO2's Avatar
Putsaround - '96 Toyota Camry LE
90 day: 32.74 mpg (US)
The Commuter - '07 Trek 1000SL
90 day: 617.28 mpg (US)
Zippy - '91 Honda Civic DX
90 day: 33.29 mpg (US)
It really depends on the car. If your car is newer and has a rev limiter in place, then the damage is probably minimal if at all. If it is an older car and doesn't have one, you would already know because your car probably wouldn't be running right now.
Personally, I wouldn't have thought twice about it if I accidentally pressed the gas pedal down for a few seconds while in neutral (maybe now I would because of wasted gas, but that's all). However, I'm not a car expert so there may be something, like valve damage or something, but I can't speak for that.
Old 06-18-2008, 09:54 AM   #3 (permalink)
The thing to worry about with revving an engine immediately after start up is engine wear due to lack of oil. During the time between cranking and oil getting to all the engine parts a lot of wear can happen. As soon as the oil is circulating through it you are okay. However, doing this once is not going to kill the engine. Just don't make a habbit of it.
BTW, welcome to the site.
Old 06-19-2008, 01:00 AM   #4 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Agreed -- not a big deal unless you do it all the time.
The hardest I've been on an engine was running for volunteer EMS/Fire ( with a new '97 Civic DX Coupe, 5-speed). Cold soak, start, high electrical loads (lights/siren), at least 2 redline runups and high RPMs for engine braking, 2.5 minutes to the station, and shut down for at least 2 hours on the average before returning home. Seconds counted, so the vehicle was put through the paces to accomplish the task.
I was warned that it could prematurely blow the head gasket with the wide swings in temps. All that happened was warped rotors with the hard stops. The vehicle was nearly totaled with a rear-end collision while stopped, just driving home. It was just over a year old. Never the same again, for sure.
Welcome, by the way!
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 06-19-2008, 09:15 PM   #5 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
And welcome from Hong Kong!
GeoMetroforum.com - got mpg?
Old 06-25-2008, 12:23 AM   #6 (permalink)
Honda Ecomodder
redline5th's Avatar
The Civic - '98 Honda Civic DX
90 day: 41.59 mpg (US)
Never rev a cold engine! Let it warm up for several minutes so that everything warms slowly. The engine might not be properly lubricated if you race the engine off the bat.
http://thechriscoleman.com/
Alas.... no more 40mpg -- Now B18C swapped.
How to smoothly bump start / clutch start an engine MetroMPG Hypermiling / EcoDriver's Ed 76 03-22-2014 07:52 AM
Porsche 911 engine swap - ideas? beatr911 EcoModding Central 20 11-17-2013 11:20 AM
Engine braking without using fuel idea Dane-ger EcoModding Central 38 02-04-2010 10:35 AM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 08:38 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
