Old 04-17-2013, 10:17 PM   #1 (permalink)
the turd - '88 honda civic 4dr DX
90 day: 73.51 mpg (US)
Question has anyone used led's for headlights
been looking into new headlights and bulbs...does anyone have info on led headlight bulbs...i know that thay use them for daytime running lights...and the difforance between the 5050 smd led's and the 3528 smd leds...and that there temp is between 5500k / 6500k...any info on this would be helpfull thank for your help.
Old 04-18-2013, 12:53 AM   #2 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Cadillac uses them on a few vehicles, you can buy them used for $1,500 each at junk yards.
Keeping them cool is part of the problem that they had.
Old 04-18-2013, 06:28 AM   #3 (permalink)
ryland thanks for info...from what i've been finding is that you can buy type 9005 bulbs that are plug & play with 102 or 120 leds in them and to put them in a set of projector headlights should work...i guest i'll have to buy them to test it out to see how well thay work at night
Old 04-18-2013, 08:01 AM   #4 (permalink)
RobertISaar's Avatar
MC SBX - '95 Chevrolet Monte Carlo LS
Last 3: 29.75 mpg (US)
and the lumen output of them makes them entirely useless as headlamps. probably fine as DRLs, but as a source of illumination, worthless.
9005 are normally highbeams, 9006 for lows. 9005 incandescent bulbs are normally around 1700 lumens, with 9006 at ~1000 lumens.
HIR automotive bulbs
alternatively, HIR bulbs put off a lot more light for an identical amount of power consumed.
how many lumens are those LED replacements rated for?
The Following User Says Thank You to RobertISaar For This Useful Post:
mcrews (04-19-2013)
Old 04-18-2013, 08:55 AM   #5 (permalink)
not sure what the lumens are...will have to check it may take a couple of days to get the info...the projector headlights that i got have the same bulb type in each ( hi/low ) which are 9005 and 65 watts...the set that are in the car right now, which are projector headlights and have h1 type bulbs and 100 watts 7500k
Old 04-18-2013, 06:46 PM   #6 (permalink)
"Lumens" are a measure of the amount of human-visible light emitted by something.
Lumen (unit) - Wikipedia, the free encyclopedia
The higher the number, the more light that we can see is thrown out. The lower the number, the less (visible) light is thrown out.
Big power (wattage) numbers don't mean much if there isn't much coming out that we can actually see.
-soD
Old 04-18-2013, 07:49 PM   #7 (permalink)
I know the prius has them as an option, but i havent been impressed. I did buy a Chinese made 3x cree 6 watt led flashlight on ebay and wow, it could replace your high beams.
Old 04-18-2013, 07:49 PM   #8 (permalink)
some other dave...im trying to fine out what the lumens are for the bulbs from the seller it may take a couple of days...the watts is only 8.
the other lights thrown out alot of light close to hid, bright white best desrcibe them in color (7500k).
will be testing them when thay get here.
Old 04-18-2013, 07:51 PM   #9 (permalink)
cobb thats were thay are coming from
Old 04-18-2013, 08:25 PM   #10 (permalink)
Ryland's Avatar
Part of the trouble with head lights is that the beam needs to cut off so it doesn't blind oncoming traffic, so cobbling together an LED fog light or search light works great but a head light that is safe is a bit more work.
