Old 04-19-2013, 09:29 PM   #21 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
1. Each type of projector lens is designed SPECIFICLY for a certain bulb.
ex: hid projector is designed ONLY for hid bulbs
Halogen prjector is ONLY designed for Halogen bulb.
PERIOD.
They CERTAINLY are not designed for led.
Please read this thread to understand. See how the wrong bulbs send uot a completely failed beam.
HID plug n play fails govt test
Also PLEASE do not run 7500.........5000 max....... really.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
The Following User Says Thank You to mcrews For This Useful Post:
niky (04-21-2013)
Old 04-19-2013, 10:20 PM   #22 (permalink)
I think 3000k to 3500k look perfect. The color light they put off mimics the whiteness of a DOT approved lamp, but its just a little whiter than normal.
Old 04-19-2013, 10:57 PM   #23 (permalink)
mcrews's Avatar
As a note:
I did run HIR bulbs in the high beam on the Infiniti Q45. There was a noticeable difference.
ECO MODS PERFORMED:
First: ScangaugeII
Old 04-20-2013, 10:00 PM   #24 (permalink)
90 day: 19.36 mpg (US)
Back to original question. See products by JW Speaker
The US Army MRAP uses these. GROTE carries the line, also.
Old 04-21-2013, 09:36 AM   #25 (permalink)
the turd - '88 honda civic 4dr DX
90 day: 73.51 mpg (US)
slowmover, thanks for the link,..but nun of them would work in the turd (1988 honda civic) good read... thank you
Old 04-21-2013, 10:17 AM   #26 (permalink)
mcrews's Avatar
Originally Posted by ajjct View Post
not sure what the lumens are...will have to check it may take a couple of days to get the info...the projector headlights that i got have the same bulb type in each ( hi/low ) which are 9005 and 65 watts...the set that are in the car right now, which are projector headlights and have h1 type bulbs and 100 watts 7500k
Just because they are "pnp" doesnt mean they work correctly.
More watts (too much) and too high 7500.
So you have alot of watts pushing no white light down the road......and the light being produced is all glare.
Consider posting a picture of the light shining against a wall from 25 ft.
ECO MODS PERFORMED:
First: ScangaugeII
Old 04-21-2013, 04:26 PM   #27 (permalink)
cant do picturs.... not sure how on cp... never got shown how....can text if give in number, mp it to me
Old 04-22-2013, 10:15 AM   #28 (permalink)
XJ Cherokee - '00 Jeep Cherokee Sport
90 day: 12.96 mpg (US)
FoFO - '11 Ford Focus SE
90 day: 36.78 mpg (US)
You don't live in a snowy climate, so it probably wouldn't be a problem, but I'd be worried about snow buildup on the headlight. LEDs don't heat up enough, or at all, to melt the snow off of the headlights.
I see it a lot with cars with LED tail lights. If they are driving in a snow storm long enough, the snow builds up on the taillights via vacuum and you can't see them!
Old 04-22-2013, 11:08 AM   #29 (permalink)
nemo's Avatar
Chief - '06 Pontiac Grand Prix
90 day: 26.7 mpg (US)
SF1 - '12 Ford Fiesta S
90 day: 30.95 mpg (US)
Application of Rain-X or synthetic wax may help with the headlights depending on the angle of the lights.
LED do in fact produce heat 70% of the power consumption is turned into heat and only 30% light (according to Wikipedia) where as 90% of the power in a standard bulb produces heat. If you are getting the the same light out put from an LED using say 10 watts as a 60 watt bulb that represents a significant reduction in heat output.
Old 04-22-2013, 11:47 AM   #30 (permalink)
RobertISaar's Avatar
MC SBX - '95 Chevrolet Monte Carlo LS
Last 3: 29.75 mpg (US)
LEDs Magazine - Cree announces a new laboratory LED efficacy milestone at SIL
only in a lab so far, but give it time and they'll show up in consumer products while even better efficiencies are created by those guys with labcoats.
276 lumens per watt... just 4 watts would make slightly better output than a 9006 incandescent bulb.
