Old 08-23-2009, 12:13 PM   #1 (permalink)
Da Truck - '91 Dodge D150
Hi From Winnipeg
First post- enjoy the site and all the info.
I have a 1991 Dodge D150, 3.9l 3 speed auto. Located in Winnipeg, Manitoba, Canada.
Mods so far:
-antenna delete
-warm air intake
-1/2 grill block
-plastic flushmount cover on headlights
-removed rear bumper, replaced with smaller wood bumper (stock bumper hung out on the sides)
-coroplast fairing off top/back of cab
-higher pressure on tires
-flush wheel covers (chrome "beauty rings" with coroplast siliconed on)
-replaced large side mirrors with some smaller streamlined ones
-rear wheel well covers
-tried the alternator delete by loosening alternator and tying off belts but check engine light would come on at highway speeds (fuel injection issue?). I have gone back to alternator for now.
-wiper blade delete (weather permitting)
-partial box cover (back 2/3)
The whole thing is flat black with the black coroplast- has a definite "Mad Max" theme going on.
Planned mods:
-front air dam
-remove rain gutters
-boat tail back (remove tailgate, fair in using coroplast)
I have gone from 19 mpg to 23 mpg (based on last tank only- unfortun ately (fortunately?), I don't put on lots of miles....). Note: those are imp. gallons, not U.S.
Darren
Old 08-23-2009, 07:35 PM   #2 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
Welcome. I have fond memories of Winnipeg, where I learned how to ride a bicycle year-round, except when powder drifted over the ice ruts. It sounds as if you are doing well with that truck. You might want to consider a belly pan instead of an air dam to maintain better clearance. I'm also quite curious about the possibility of a really lightweight aerocap made of Coroplast and framing that is hinged at one side for bed access.
Old 08-24-2009, 01:51 AM   #3 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Welcome to ecomodder! Pictures?
Old 08-24-2009, 02:28 AM   #4 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
dizzydee -
Welcome to EM! Mad Max Ecomodder, ha ha. 21% jump in mileage es muy bien.
CarloSW2
American Solar Energy Society
Old 08-24-2009, 12:59 PM   #5 (permalink)
Pictures of Max are in the "Garage".
darren
Old 08-25-2009, 06:09 PM   #6 (permalink)
Pictures of Max
ID:	4097   Click image for larger version
ID:	4098   Click image for larger version
Old 08-27-2009, 11:06 AM   #7 (permalink)
Aero Apprentice
swede's Avatar
Hi dizzy. I just joined as well and nice to see a fellow winnipegger here.
Old 08-27-2009, 05:37 PM   #8 (permalink)
Bicycle Bob, I too cycle year round here. Coldest I have done is -35 degrees C. I have an old fixed gear with studded tires- a good workout.
I have thought about fairing in the whole back end and using a wireless backup camera (the little mirrors I added are poor compared to the stock ones. For now I will stick with the current configuration.
Darren
Old 08-27-2009, 06:10 PM   #9 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
dizzydee -
Like those pix. Now Max just needs a snake-graphic and a bed-mounted machine gun to finish its Road Warrior look :
CarloSW2
Old 05-22-2015, 02:02 AM   #10 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Was the water pump hooked up ? Sirpintine belt? Discontinued alt. = no power steering p code. No water pump /maby some windmilling except 50% grill block an other p code on smog pump/air injection pre cat for finishing fuel burn aka o*2 sencer is reporting p code
what codes came up for alt deleted test
try disconnecting and tape upthe wires or if possible pull the fuse For an ABAtest
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
Why my gas mileage sucks. Big time. Peakster The Lounge 4 01-01-2008 04:38 AM
