Old 03-01-2019, 04:13 AM   #11 (permalink)
cuda47's Avatar
Yes.
I know both engines, and with an eo remap, it is possible to improve consumption
Old 03-02-2019, 11:50 PM   #12 (permalink)
Those remaps seem to be quite popular in Spain
Old 03-03-2019, 12:02 AM   #13 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
I would be quite interested in the results if you do an eco remap of PSA's 1.6 HDI.
I recently switched from the 16v 1.6 HDI to the 8v 1.6 e-HDI and am impressed with the improvement. If it could be remapped to better focus on eco, then it would rock!
eˇcoˇmodˇding: the art of turning vehicles into what they should be
Old 03-03-2019, 12:09 AM   #14 (permalink)
Considering that 16-valve engines were hailed as a great evolution around 20 years ago, it does sound quite surprising that PSA took the opposite route with the DV6. IIRC the reason claimed for that move was emissions control.
Old 03-03-2019, 10:25 AM   #15 (permalink)
cuda47's Avatar
=> In Europe engines are often remapped, but in the way to change torque and power, sometimes, they are more eco...
My idea is not to touch these characteristic (homolgation), but to modify only the mapping point of a daily using.
Old 03-05-2019, 01:32 PM   #16 (permalink)
90 day: 51.82 mpg (US)
Originally Posted by cuda47 View Post
I bought a Turbogauge to improve the fuel consumption, but, for me it does not match well...
I searched for Turbogauge, and it looks like a version of the ScanGauge made in the U.S.
If it is similar, there should be a feature that allows you to calibrate your readings to better match the car's actual consumption. You enter an "offset" fuel use value manually, or simply tell it how much fuel you used at each fill. After a few tanks, it should be pretty close.
Old 03-05-2019, 02:42 PM   #17 (permalink)
cuda47's Avatar
I worked for the R&D département for this engine
The Following User Says Thank You to cuda47 For This Useful Post:
MetroMPG (03-05-2019)
Old 03-05-2019, 03:45 PM   #18 (permalink)
Cool!
Old 03-06-2019, 10:35 AM   #19 (permalink)
Renault - '06 Renault Megane II
90 day: 38.41 mpg (US)
How much do you have in Megane II CC 2.0 T ???
Old 03-06-2019, 10:39 AM   #20 (permalink)
cuda47's Avatar
How much?
