Old 05-24-2009, 11:57 AM   #1 (permalink)
93 Geo Metro
Sippy - '93 Geo Metro Convertible
90 day: 43.8 mpg (US)
Help needed - 999 MPG instant - 93 Metro
I just got my new MPGuino straight from opengauge.org in the mail a couple of days ago. I hooked it up to my '93 Geo Metro Convt today and I am seeing 999 MPG instant. I believe I used the default setup on everything with the exception of vehicle weight (I think I put something in like 1600 or so). Anyway, if I am driving 35 MPH and go to screen #1 it shows:
9999/"working MPH"
9999/"working distance"
If I go to screen #8 it shows:
1.4/G0000000 (never changes)
Can anyone help me troubleshoot this thing?
I have the unit hooked straight to the ECU (well, using the wiring harness at the ECU). You can see my install here (work in progress):
http://www.lightweightmiata.com/geo/mpguino/
Old 05-24-2009, 12:38 PM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
I've had bad luck tapping the injector at the ECU. I usually go straight to the injector.
I just added a section to the wiki for identifying connections:
MPGuino - EcoModder
Old 05-24-2009, 06:26 PM   #3 (permalink)
93 Geo Metro
Does the info I posted lead you to believe the INJ wire is not hooked up? That is what I could not tell so I was asking here. If I am not getting that signal I will try tapping at a different place.
Any idea why I could not get a signal at the ECU but I will be able to get one at the INJ? Doesn't make any sense...
Old 05-24-2009, 06:41 PM   #4 (permalink)
dcb
needs more cowbell
dcb's Avatar
Yup, you should see a gph signal on the main (custom) screen if the injector signal is hooked up correctly. Don't know why the trouble at the ECU, but tapping at the injector eliminates a lot of variables.
Old 05-24-2009, 07:24 PM   #5 (permalink)
93 Geo Metro
Thanks!
Old 05-25-2009, 04:01 AM   #6 (permalink)
93 Geo Metro
Hooking up straight to the injector fixed it. I am not sure why I couldn't get it to work using the wire at the ECU. I will investigate this further when I get a chance. For now, I am going to start rebuilding the engine so I won't have time to play with it for a while.
Old 05-25-2009, 07:38 AM   #7 (permalink)
dcb
needs more cowbell
dcb's Avatar
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 1061 01-17-2020 01:37 AM
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
How to get instant fuel consumption from Megasquirt TELVM Instrumentation 11 08-29-2011 02:47 PM
mpguino acted up today, lost mpg during fuel cut wagonman76 OpenGauge / MPGuino FE computer 9 06-17-2009 12:25 PM
Tuning an 1993 Geo Metro Up from 32 MPG. Zorro DIY / How-to 6 04-29-2009 08:18 AM
