Old 09-17-2013, 11:50 PM   #1 (permalink)
Exceptional Member
YukonCornelius's Avatar
Crapolier - '98 Chevrolet Cavalier base
90 day: 34.81 mpg (US)
05 CTS-V - '05 cadillac cts-v
90 day: 33.01 mpg (US)
95 Accord - '95 Honda Accord
90 day: 38.06 mpg (US)
11 CTS-V - '11 Cadillac CTS-V
Honda drivers, are you accounting for the inflated odometer reading in your MPG?
This should be a lively topic. I've often thought about this and never notice anyone mention it in their mileage calculations. Honda has been sued over their bogus odometer readings, I believe more than once. I recall a warranty extension for millions of cars. I know my 95 Accord reads conveniently high. Not the quite the 4% of some Honda's but still too much. This issue applies to some Nissan/Infiniti vehicles as well. I know no one likes getting lower mpg but I think we all appreciate accuracy.
Don't know why it says 00, it's a 95
374,000 miles and tired.
Old 09-18-2013, 12:14 AM   #2 (permalink)
cbaber's Avatar
Lean and Mean - '98 Honda Civic HX
90 day: 46.69 mpg (US)
In my 98 Civic, the speedo is off, yet the odometer is right on the money in factory form. Since I have over sized tires, I have to add 5% distance to my MPG calculations, but it corrected the factory speedometer to GPS indicated speed.
I originally believed that since my speedometer was indicating the GPS speed, my odometer must be accurate. Guess not!
1998 Honda Civic HX - My Project Thread
Old 09-18-2013, 12:19 AM   #3 (permalink)
Exceptional Member
That's a twist, I expected the two to be in sync. I better check my OD now.
Old 09-18-2013, 02:40 AM   #4 (permalink)
Wanting more for less
D.O.G.'s Avatar
Metric - '94 Honda Magna 250
Motorcycle
90 day: 69.83 mpg (US)
RedCelica - '94 Toyota Celica ZR
90 day: 35.97 mpg (US)
i30 - '12 Hyundai i30 Elite
90 day: 39.84 mpg (US)
i30-22 - '12 Hyundai i30 Elite
90 day: 39.22 mpg (US)
It's not only Hondas, I found similar inaccuracy with my Mazda.
On standard size tyres, the speedo reads fast & the odo reads slow (compared to my GPS).
On the taller tyres I run now, the speedo is correct and I multiply the odo readings by 1.057 when calculating my MPG.
Old 09-18-2013, 02:49 AM   #5 (permalink)
5 Gears of Fury
War_Wagon's Avatar
Spunky - '90 Honda Civic CX
90 day: 35.56 mpg (US)
My Honda is 23 years old, I would think that any issues it came with have only been made worse over the years. But for me, since I don't use GPS or any other instrumentation to verify my results, I am not super concerned with the accuracy of the odometer. Maybe I avg 37 mpg, maybe in reality it's 34? The part that interests me is the improvement I can make in whatever number I am getting. I am assuming that any issues with accuracy are at least consistent issues (ie being off a few percent when new compounded with years of wear), so as long as everything stays at the same level of broken then I can at least track my improvements!
"Don't look for one place to lose 100 pounds, look for 1600 places to lose an ounce." - Tony DeFeo
Old 09-18-2013, 02:50 AM   #6 (permalink)
I don't have a Honda but I do have to make an odometer correction.
I have checked my odometer against mile markers and GPS, averaged the difference (less than 1% between the 2 methods) and figured I have to add 3% to my suburban odometer mileage.
Found out recently that is because some time in the past the 3.08 rear end that my suburban left the factory came with was swapped for a 3.42 unit.
Old 09-18-2013, 04:11 AM   #7 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
I checked my odometer against a GPS and I have to adjust my mileage. My odometer is actually underreporting due to the size of my tires.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
Old 09-18-2013, 04:26 AM   #8 (permalink)
90 day: 57.12 mpg (US)
My odometer is underreporting by at least 1%.
Yesterday I took a trip that both Google and my TomTom said would be 83.1 km long.
Ended up @ 82 km dead on the driveway.
I see the same pattern on my commute: the odometer reports about 0.5 km less than the GPS shows for 36 km.
Car has the original 185/55/R16 tires for 15,000 km. Same with the 175/65/R15 winter tires.
I did add liters to my fuel log for using a fuel pump that is off. Should I now also add some kms for my underreading odometer?
When precision and vanity go hand in hand, should I give in?
Old 09-18-2013, 03:12 PM   #9 (permalink)
darcane's Avatar
In Washington state, there are a bunch of odometer check stations on the freeway. Five miles, precisely marked off in one mile increments. Based on that I know my odometer is 1% or less off in my '01 Civic. That's close enough for me.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
Old 09-18-2013, 05:01 PM   #10 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
1% is 1%
I'd add it.
I'm adding 3.4% due to larger tyres, but I really should check the odometer against GPS / kilometre signposts.
In my experience though,
speed is always overreported
(as legally they may not show you're going slower than you actually are)
odometer OTOH is quite correct
In the up! , the speedo even shows a different speed than the digital speed readout buried in the OBC !
Speedo indicates highest.
OBC reports a few kph less than speedo.
GPS reports yet another few kph less than OBC ...
And that's even despite the tires being too large!
