Old 04-29-2014, 06:32 PM   #61 (permalink)
ALL UP ON THE INTERWEB!!!
vrmouseyd15b's Avatar
skidmark - super snail - '89 honda civic wagon WAGOVAN
Team "Old SKOOL"
90 day: 30.87 mpg (US)
Pituca - '19 Honda Insight Touring
90 day: 39.34 mpg (US)
yeah! it's sick! I just ran 362.1 miles from full, 8.801 gallons to refill = 41.143mpg! I gotta get that tranny! the numbers speak for themselves!
Old 04-29-2014, 08:07 PM   #62 (permalink)
Team "Old SKOOL"
Originally Posted by California98Civic View Post
Very nice. 2750 rpm at 70 mph is about what you'd expect from the 97 LX trans with the 0.702 fifth and 4.058 final drive. But lean burn? Seems pretty impressive to be in lean burn at 70mph. I think basjoos does that in his heavily aeromodded Civic. But that's about it.
I gotta be different, LOL!!
Old 04-29-2014, 10:42 PM   #63 (permalink)
What tweaks did you do to the tps and ignition timing.
Old 04-29-2014, 11:15 PM   #64 (permalink)
Team "Old SKOOL"
I was coming from a chipped p28 ecu, the tps was way off coming back to a stock ecu. set to.5 volt @ no throttle, 4.5 volt @ wide open throttle (on center wire @ tps to ground, basic d - series honda style(most people don't touch these things, as they are not meant to be removed, nor are they adjustable from the factory - they'd rather the throttle body be replaced, but I like to be different!)). Then I re-set timing from the distributor to the first line of retarded ( I think, the one closest to the front bumper of the three lines in a group on the harmonic balancer).
Basically stock settings, just a little retarded LOL!!!
Old 04-29-2014, 11:20 PM   #65 (permalink)
Team "Old SKOOL"
I'm totally jacking this thread
MODERATOR: PLEASE P.M. ME - I think I should just throw my on thread and leave the trans/gears guys alone. Where to go?
Old 04-30-2014, 12:29 AM   #66 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Go into the ecomodding central subforum and start a build thread specifically for your car. Best aay to create a story of your foibles, victories, and frustrations as the car progresses...
vrmouseyd15b (04-30-2014)
Old 04-30-2014, 12:31 AM   #67 (permalink)
Team "Old SKOOL"
thanks! I'll do it soon!
Old 04-30-2014, 02:12 AM   #68 (permalink)
So basicly tps was reset to stock and you retarded the ignition timing.
Old 05-04-2014, 08:35 PM   #69 (permalink)
Team "Old SKOOL"
yup. that's about it.
Old 09-08-2014, 05:11 PM   #70 (permalink)
California98Civic, great work! Is there a reason that you did not include the Civic Si? The 98-00 had a 4.266 final drive, according to Honda Civic (sixth generation) - Wikipedia, the free encyclopedia, which strangely omits that detail for the HX.
