Old 03-21-2009, 04:27 PM   #1 (permalink)
90 day: 51.82 mpg (US)
Honda Ridgeline MPG vs speed graph: fuel economy with & without cargo trailer
Another one to add to the pile. My brother's 2007 Ridgeline that he uses for his HVAC business:
Note: the '07 Ridgeline is rated by the EPA at:
I'll post the full details later, but it's pretty close to the same conditions & test method as the Corolla speed vs. mpg graph.
The truck has a full hard tonneau, and I inflated the tires to max sidewall.
Edit: here are the raw figures:
Without the trailer:
Code:
W (mpg US) ... E (mpg US) ... Avg
29.2 ... 28.3 ... 28.75
28.0 ... 30.0 ... 29
24.7 ... 27.2 ... 25.95
27.2 ... 29.2 ... 28.2
24.8 ... 26.6 ... 25.7
22.4 ... 24.3 ... 23.35
20.4 ... 21.1 ... 20.75
19.7 ... 21.4 ... 20.55
With the trailer:
Code:
 22.5 ... 25.4 ... 23.95
21.8 ... 24.2 ... 23
17.6 ... 18.9 ... 18.25
12.9 ... 16.7 ... 14.8
Conditions, route & methodology:
Weather conditions: 29 Dec '08, 34 F / 1 C, wind SSE 9 kts, pressure 29.6 in.
Route: 2 lane highway, straight, dry & nearly level
Methodology:
Speed was set once per pair of bi-dir runs with cruise control, cancelled with the brake between runs. Truck was brought up to speed & leveled off before passing a "start" marker (road sign) where the ScanGauge (not calibrated against refuelling) was reset. Reading was taken after passing a "finish" marker and cruise was cancelled.
Traffic conditions: There was no traffic in my lane and very little in the oncoming lane. (More than a few runs were done with me being the only car on that stretch of road.) If anyone caught up & overtook me, or if I caught up to another car, I ditched that run and did it again to avoid aero interference.
See also ....
Old 03-21-2009, 05:46 PM   #2 (permalink)
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Toyota Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Versa Sedan 1.6 Base
90 day: 41.69 mpg (US)
Automatic?
Nissan Versa Aeromods
Old 03-21-2009, 05:55 PM   #3 (permalink)
bhazard's Avatar
2012 Golf TDI - '12 Volkswagen Golf TDI
90 day: 45.51 mpg (US)
Arent they all?
'05 Outback XT, 19 mpg
BP-turbo 93 Festiva (long gone)
1/4 mile - 12.50@111.5
Best MPG - 36.8
Old 03-24-2009, 10:23 AM   #4 (permalink)
Yes, they're all automatics. I think it's a 4 speed/overdrive.
Here's the type of trailer used:
Old 04-09-2009, 11:57 PM   #5 (permalink)
Smile Over 25mpg for a whole tank?
I don't have a tonneau and have to baby mine to break 20mpg.
What's the secret?
Old 04-10-2009, 10:44 AM   #6 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
My 04 Odyssey 3.5 V6 is a 5-speed auto. I'm almost positive this is the same.
My results match, especially the dip at 43 mph. The shift points are 10, 20, 30, and 45 mph. See that last one? It doesn't match. The 40-45 mph span is just painful as the engine revs but won't shift. I generally try to keep it below 40 or above 45. You can do a quick D-N-D shift and get it to shift sooner, down to about 42 mph.
Old 04-10-2009, 05:57 PM   #7 (permalink)
Ridgeline Rookie: I haven't driven the truck for a full tank, so I can't tell you what it's capable of.
Note that the figures in the graph are taken from bi-directional runs of about 1.6 km each way.
But I'd say you could easily beat 20 mpg for a highway tank, not even using any special driving techniques. You just have to keep the speed down.
Old 04-10-2009, 06:19 PM   #8 (permalink)
Same specs on the Ridgeline - 5-speed.
The truck will hold top gear below 43 after it has engaged, so I could have accelerated above 45, then dropped down to 43 (70 km/h) and that would have undoubtedly been the high point in the graph.
But I decided to do the runs straight up, no messin' around.
Old 04-10-2009, 07:48 PM   #9 (permalink)
Hypermiler
Wagons
Again, same behavior here. Doing the D-N-D shift makes it think it was already in 5th, and it'll drop right down and hold it. I use this all the time.
I agree with your decision to go straight up.
Old 04-10-2009, 07:53 PM   #10 (permalink)
How in the world did you figure out the D-N-D trick?
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
SuperMID - Fuel Economy Display SVOboy Instrumentation 25 05-15-2015 09:16 PM
How to calculate MPG / fuel economy formula MetroMPG DIY / How-to 29 11-25-2013 06:47 PM
Why SUV fuel economy is so much more important than small car fuel economy... SVOboy General Efficiency Discussion 30 02-23-2009 06:26 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
