Old 08-06-2010, 07:06 PM   #1 (permalink)
NightKnight
NachtRitter's Avatar
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 54.39 mpg (US)
Mathilde - '99 Volkswagen Eurovan Camper
90 day: 16.87 mpg (US)
'Pop-out' rear 1/4 windows for 5th gen Civic?
I (personally) like the way the rear quarter windows on the 4th gen Civic hatchback can open (other makes/models use the same approach, esp. mini-vans), but sadly the ones on my 5th gen VX do not open, and I haven't seen the "open-able" style on any other 5th gen hatchback. Question I have is if anyone familiar with Civics (ahem, SVOBoy ... and others) knows of an aftermarket solution for the 5th gen hatchback so that the rear quarter windows can be opened or if it's simply impossible due to the design of that gen's rear quarter windows? Yes, I've searched, and I even have a hard time finding information about the 4th gen mechanism... I must be using the wrong search terms.
From aero perspective, it *seems* like this approach would be preferable over rolling down the driver & passenger windows enough to get decent air flow. However, that's just a WAG and would require some verification. From a comfort perspective, it sure would be nice to have a way to pull the air through the cabin without needing to turn on the cabin fan or roll down the front windows...
For those that aren't sure what I'm talking about, this image from the 4th gen HB service manual may help:
The bottom image shows the latch that allows the user to 'pop' out the rear edge of the quarter window. The front edge of the window is hinged.
Last edited by NachtRitter; 08-06-2010 at 07:08 PM.. Reason: Added search disclaimer
Old 08-06-2010, 10:44 PM   #2 (permalink)
OG ONR 320k
I have also wondered about the same feature. even taking it one step further and motorizing it with minivan parts. that way i can vent it with my alarm.
Old 08-06-2010, 10:58 PM   #3 (permalink)
...beats walking...
...my 1984 Civic DX had those same "pop-out" rear windows.
Old 08-08-2010, 11:34 AM   #4 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
I happen to have a 1984 civic DX hatch back with these windows, the car was rear ended and totaled, I suspect it would be a tough job to retrofit them to a car that is 10 years newer but you never know.
I really liked using those rear windows to vent hot air out of the car both while parked and while driving.
Old 08-09-2010, 04:52 PM   #5 (permalink)
NightKnight
Diesel
Pretty much sounds like it has to be a 'DIY' solution... I haven't found anything on an aftermarket solution. Probably would have work with an auto shop to come up with a solution... drat.
Old 08-10-2010, 12:10 PM   #6 (permalink)
EcoMod Proof of Concept
WD40's Avatar
WD-40's Insight - '00 Honda Insight
Gen-1 Insights
90 day: 56.04 mpg (US)
WD-40's Mirage - '15 Mitsubushi Mirage ES
90 day: 46.05 mpg (US)
WD-40's Sonata Hybrid - '17 Hyundai Sonata Hybrid Limited
I had the same idea during the last hot spell, the civic has crappy air flow, and the this would definitely help solve that issue, I do have a flip up sunroof that helps but I think it also lets it way more heat then it removes.
2000 Insight MT 106K Citrus A/C
Canadian 8th Gen. Civic Gears superchow EcoModding Central 1 06-20-2013 11:52 AM
Drag Racing Aero Help Bennett_Racing Aerodynamics 33 06-28-2010 06:02 AM
Any info on 1st gen civic hybrid wheels? weight, value. Ryland EcoModding Central 1 04-11-2010 08:44 PM
Honda Civic 5th gen and 6th gen jennyfurwhen Off-Topic Tech 15 10-01-2009 12:44 AM
FS: Carbon Fiber Hatch for 5th Gen Civic trikkonceptz For Sale 8 06-04-2008 04:40 AM
