08-04-2010, 07:52 PM
Using Magnets to increase milage
Last year I posted a thread about increasing milage using high powered magnets. I stated I would do a A-B-A test.
I am still getting 34-35 mpg with ethenol fuel. I did an A-B-A test. The milage stayed the same when I took off the magnets.
My conclusions are that the magnet conditions the fuel and the ECU senses the change and adjusts fuel delivery rate to compensate. As the magnets clean out the combustion chamber, it would take thousands of miles to return the carbon buildup and varnish to make the ECU return to orginal mode.
I believe the fuel we pump is stale and contaminated with particles from air and tank like leaving fuel in a lawnmower over the winter. I think the magnet restores the fuel to original form, expanding it, then the ECU senses it and reduces the fuel flow.
08-04-2010, 08:29 PM
Left Lane Ecodriver
A-B-A test show no difference with fuel rail magnets. Fuel rail magnets don't work.
If you had stopped there, I would have nothing to disagree with.
If you try some studies outside of a car, I think you'll find magnetic fields have little to no impact on fuel. Further study will demonstrate that fuel filters, before and after the fuel pump, remove the particulates you mentioned.
Here's one for you. Stick a magnet on cylinders #2,4 fuel injectors. Pop the cylinder head off in two years, and I'll bet you dollars to donuts there's no discernable difference in combustion chamber cleanliness.
The Following User Says Thank You to RobertSmalls For This Useful Post:
08-04-2010, 08:33 PM
Basjoos Wannabe
only way magnets help gas mileage is if they are part of an electric motor.
 RIP Maxima 1997-2012
Originally Posted by jamesqf
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
The Following 3 Users Say Thank You to ShadeTreeMech For This Useful Post:
08-04-2010, 08:36 PM
...beats walking...
...actually, the *best* use of a magnet in the pursuit of fuel-economy, is to use one to hold your SGII securely onto the dash for easiest viewing.
The Following 5 Users Say Thank You to gone-ot For This Useful Post:
08-04-2010, 08:50 PM
Wiki Mod
junk
I think that magnets are a not going to work, else they would come new that way. the chemistry also does not work that way. if in that short of time it can change the molecular shape they in the same time it will move back.
08-04-2010, 08:57 PM
Bus - '94 Ford School Bus huge Stupid - '01 Chevy Blazer LS 90 day: 21.38 mpg (US) hawk - '00 Honda Superhawk
I think that you would find that the magnets would destroy the injector, an electro magnet.
08-04-2010, 09:19 PM
Gen II Prianista
Maybe this would work:
(I think it's been PhotoShopped.  )
08-05-2010, 12:46 AM
Yeah. The only way you're going to increase mpg with magnets is to mount one on a long pole (perhaps telescoping?) sticking out the front bumper, then drive close enough behind a semi that you can "latch on" to it.
Which might even be a safe way of drafting, if the pole had some shock absorbing capability...
The Following User Says Thank You to jamesqf For This Useful Post:
08-05-2010, 02:26 AM
#9 (permalink)
NightKnight
I believe you will believe whatever you want to believe in order to believe that the magnets work...
08-05-2010, 06:34 AM
#10 (permalink)
I can't see how magnets could be used to 'condition the fuel' if there was enough effect on the particles to pull them into alignment (as some of these wonder things suggest) surely cars would suffer huge amounts of fuels starvation and pressure spoting from fuels passing close to Hi ouput electrics, like the start solenoid, alternator or starter motor etc.
Also i have to agree about the a-b-a thing. If you add something on the B test and nothing changes, ITS NOT HAVING AN EFFECT. if it did change from a-b but stayed the same b-a then it was a purely placebic change like an improvement in your base driving style.
good things come to those who wait, sh*t turns up pretty much instantly
twitter.com/bertchalmers
