Old 11-13-2012, 03:35 PM   #11 (permalink)
INefficient electric mode? Many plugin electrics/hybrids are ~85% efficient plug-to-wheels; while the Prius' engine is just 38% efficient, at best.
My opinion on why Honda hasn't sold very many hybrids is that the Prius beats the Insight (2nd gen) by 8-10mpg while seating 5 vs 4 for the Insight.
I'm looking forward to hearing the details on the new i-DCT hybrid system. Competition means improvements all around.
Old 11-13-2012, 04:04 PM   #12 (permalink)
Aero Deshi
ChazInMT's Avatar
MagMetalCivic - '04 Honda Civic Sedan EX
Last 3: 34.25 mpg (US)
Honda has a DCT motorcycle that seems pretty slick, I read about it here. (Honda Crosstourer) I think the car i-DCD thing is maybe an application of this.
Great read, I see they mention the 3 motor thing I posted about earlier in Honda 3 Motors in 1 Car
For conversation starters....you don't suppose Apple will sue them for calling it i-DCD do you? Does Apple own all things i?
Last edited by ChazInMT; 11-13-2012 at 04:17 PM.. Reason: Things change, wind blows, trees grow
Old 11-13-2012, 04:08 PM   #13 (permalink)
90 day: 51.82 mpg (US)
Chaz - noted & corrected in the thread title. Thanks.
Originally Posted by jamesqf View Post
inefficient electric-only mode
Note Honda's statement about the 30% efficiency increase over previous IMA hybrid system. Think it's safe to say electric mode isn't making things worse.
Old 11-13-2012, 04:10 PM   #14 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by UltArc View Post
I hope focus isn't shifting away from hydrogen. But, this does seems pomising.
Hydrogen isn't going to happen.
The drawbacks are even worse than for electric cars.
Old 11-14-2012, 12:02 AM   #15 (permalink)
That's right, the Prius is a bigger and more practical car than even the Civic Hybrid I think. I sat in a rental 2nd gen Prius and it felt rather roomy inside compared to most compact cars. The hatch helps with storage space a ton too.
i-DCT sounds pretty good to me. To be honest, I think the clutched electric motor setup is how it should've been all along.
Old 11-14-2012, 11:09 AM   #16 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
If they can couple the efficient lean burn system they had on the insight I with a MT and a clutched EV side instead I would be all for it
erm...
That said if their system works as well as a Prius but their motor has lower BSFC we can only hope they eventually make their way to having a MT version like every other Honda
Old 11-14-2012, 11:40 AM   #17 (permalink)
Yes, inefficient. Especially for a non-plugin, but even with plugin it's usually more efficient to use engine and electric motor together than to use one, then the other.
Old 11-14-2012, 03:10 PM   #18 (permalink)
As an aftermarket plug in insight owner I choose to abuse the undocumented "ev" mode to coast longer once accelerated to speed by the mix of the two per the onboard computer. Of course having a higher state of charge the system automatically mixes in more electrical power or assist than it would otherwise. The limit is similar to the prius 2/3 in the fact its only under light throttle, otherwise the ice kicks back on and both are used.
I imagine having the plug in ability may cause a skew in mpg from the drivers stand point trying to conserve the energy since its limited or use more of the ev feature.
Then of course you got the other fact most hybrids give best fuel economy when you use the least of the electric as possible.
I like the fact I can keep up with traffic never exceeding 80 mph and still clocking 54 mpg on the mid.
Old 11-16-2012, 11:16 PM   #19 (permalink)
eco-scrapper
Big Blue - '94 Ford F-150 shortbed
90 day: 15.71 mpg (US)
Mexico Nuevo - '84 Honda V45 Sabre
90 day: 36.67 mpg (US)
Could jamesqf (or anyone else) tell me what's inefficient about even only?
When I'm lucky enough to borrow mom's Fusion, I simply capture regent charge during the inevitable (I live in the Appalachians) descent, and run ev-only to the 50% SOC the Fusion likes to maintain.
That's better than efficient; it's effectively "found energy."
I agree that running EV is dumb--if you reasonably forsee having to burn Dino juice to recharge. I suppose if you lived somewhere billiard-table flat, you might almost never use EV optimally.
But if you live somewhere "steeper than the speed limit"?
Old 12-03-2012, 01:06 PM   #20 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
I agree. Can you say "Hindenburg"?
I'm not saying hydrogen can't be done safely. But i think there is considerable consumer resistance. With the added challenge of launching a new distribution network, hydrogen has a big uphill climb here.
Anyway, I'm very glad to read of Honda's new scheme.
One possible benefit that's been hinted at between the lines: so far as I know, most (all??) electronic dual clutch transmissions also offer paddle shifters for functionality close to what you get from a traditional standard. I see it more as an automatically shifting standard rather than an automatic with clutches.
Coast long and prosper.
