Old 01-28-2012, 07:47 AM   #11 (permalink)
TurnpikeCruiser's Avatar
Big Merc - '94 Ford F150 XL
The Cherry Bomb - '88 Mercury Grand Marquis LS
Luxoliner - '07 Mercury Grand Marquis LS
Team Panther
90 day: 23.63 mpg (US)
I couldn't detect any aero improvement via better fuel economy with an aero winter front. It almost has to be doing some aero good, but don't think that if you get 18, suddenly you will get 19 or more. The main thing it does is promote fast warm-up and also retains heat far better between commutes.
I'm not expecting it to really see an increase, just playing with ideas, as I've never done anything aerodynamic to a car before. So figured I'd start with something easy.
Originally Posted by bikin' Ed View Post
On my Dakota, the hood latch has to be pulled down. I attached a piece of plastic tubing to the inside of the grille with nylon wire ties. Then attached a piece of semi rigid wire to the latch. I fed the wire thru the tube to the bottom of the grill. Make a small loop in the end of the wire and hang it between the bumper and grille. A pull on the loop does the trick.
That's a good idea. I'd have to bring mine to the side, as my latch moves horizontally, but I probably do something similar.
Old 01-31-2014, 10:41 AM   #12 (permalink)
Diesel FTW
PAFirefighter11's Avatar
Golf TDI - '03 Volskwagen Golf TDI GL
90 day: 44.63 mpg (US)
Something else to consider if you do end up blocking both grilles would be hood pins:
http://www.summitracing.com/search/part-type/hood-pins
Lots of different styles to choose from. This way you can disconnect your current setup and just use the hood pins to hold the hood down. No need to worry about the lever in the grille. Just a thought!
-Rick R
-'03 Volkswagen Golf TDI (49.9 MPG - Stock with Eco Friendly Tires
-'98 Jeep Grand Cherokee 5.9L - 32" MTZ's, 4.5" lift (11.5 MPG)
-'98 Pontiac Firebird Trans Am WS7 5.7L (22 MPG)
-'01 Pontiac Firebird Trans Am WS6 5.7L (22 MPG)
Old 02-01-2014, 10:14 AM   #13 (permalink)
Too busy for gas stations
Superfuelgero's Avatar
Turtle - '92 Honda Civic Vx
90 day: 67.09 mpg (US)
Rolla - '10 Toyota Corolla Le
Beast - '91 Chevy V2500
Bus - '01 VW Eurovan MV
Speed - '93 Harley bored and storked Harley w/ turbo/ nitrous
90 day: 53.09 mpg (US)
Cal - '68 Ford Mustang GT/CS
I just left an opening. You can always cover with tape, (or if metal) magnetic strips.
My opening is just a hand hold since its a 1 piece front end, but the concept is the same.
Shooting for 600 miles of range at 65-70 mph out of a vx.
Old 02-01-2014, 01:47 PM   #14 (permalink)
Team Panther
Woah, reviving an old thread!
Interesting thought on hood pins, although the truck probably won't be ecomodded anymore.
Old 02-01-2014, 02:03 PM   #15 (permalink)
Xntrx, that is beautiful! Where did you get it?
How much drag would hood pins create?
Old 02-02-2014, 11:54 AM   #16 (permalink)
Used off craigslist. The pins aren't pins, they're bungies since I'm still tweaking the fit. Drag would be negligible since they're narrow and just aft the leading edge.
The grill block is just sheet aluminum pop riveted on. The holes are; a hand hold slot and two dimple die holes in front of the radiator (added over the slot wasn't enough summer cooling).
