Old 04-06-2011, 09:30 AM   #51 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
As long as you're looking into vehicle mods, a lockup switch seems to have proven gains...
Old 02-13-2015, 11:11 PM   #52 (permalink)
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
Originally Posted by Sularus View Post
This is what was done to aerocivic. As far as the angle goes I am not sure, but I would think an angle meeting up with the top edge of the windshield where the roof begins would help and it somewhat bisects the difference of the hood-windshield transition.
Aerocivic - aerodynamic mods for maximum fuel economy - aerocivic.com
J
I'm mulling over something along those lines. The transition angle on my truck is pretty steep, and I figured I could solvent weld some ABS to the plastic tray and improve the transition.
Old 02-14-2015, 09:55 AM   #53 (permalink)
Cd
Ultimate Fail
Cd's Avatar
I totally missed this thread, so I skipped several pages to get here and post.
Forgive me if you answered this already.
What are you main goals ? Do you intend to off-road the vehicle ?
If this is to be a city only vehicle, it seems that the main areas that could use some improvement would be the areas around the wheels and the grille.
( beside the obvious rear of the vehicle, which you don't want to modify ( correct ? )
Personally, I would lower the vehicle, add a grille block, and belly pan and then 'stealth' gap fillers above the wheels. An air dam , and then smooth ( er ) wheels.
That should cut quite a bit of drag off the vehicle and ...actually improve the looks of the vehicle ( I saw a jeep just like yours yesterday that was lowered. I like the look )
Old 02-14-2015, 01:01 PM   #54 (permalink)
some visuals
If the Liberty had as clean a nose as a 1975 VW Golf/Rabbit (which it does) the forebody flow would be fine
And the flow over the roof is good such that aft-body mods will have a good 'source/onset' flow
The wake is the issue
The wake almost 'tells' us what it wants
Your receiver hitch mounted cargo carrier can be the foundation for a boat tail.You'll be surprised by its effect,even at limited length.
They're kinda like a blow out preventer which minimizes an oil spill behind your JEEP,keeping more fuel in the tank.
BamZipPow (02-14-2015), ECONORAM (02-16-2015)
