Old 05-09-2010, 02:25 PM   #1 (permalink)
hooking up an egr...
86 toyota 22r.I've stripped off all the smog stuff except the egr valve.What needs to also be connected in order for it to work?
Old 05-10-2010, 08:03 PM   #2 (permalink)
oldscoob - '87 subaru wagon gl/dr
90 day: 47.06 mpg (US)
EGR valves...
cali plays with that stuff, my locale goes insane over it.
it got so bad I made the spot it was in a heatsink until the radioactive ticks finally decide to leve my precious brain alone, and bottom of windshield, and exhaust sytem, valves, headgaskets, and fuel mileage.. but its up to you to get it going. There is not one reason for itys existence. there is pros around here that taught me how to get it out of the sytem. The 22r is a classic for toyota..you may be able to argue some reason.
If california has not deciphered how bad that 1970s-80s spree was and allowing for removal, you may be out of a good toyota.
Old 05-10-2010, 09:52 PM   #3 (permalink)
Originally Posted by bgd73 View Post
egr valves...
Cali plays with that stuff, my locale goes insane over it.
It got so bad i made the spot it was in a heatsink until the radioactive ticks finally decide to leve my precious brain alone, and bottom of windshield, and exhaust sytem, valves, headgaskets, and fuel mileage.. But its up to you to get it going. There is not one reason for itys existence. There is pros around here that taught me how to get it out of the sytem. The 22r is a classic for toyota..you may be able to argue some reason.
how about making some sense???
Old 05-11-2010, 08:01 AM   #4 (permalink)
Is there a vacuum diagram under the hood? There should be a vacuum line and vsv going to it to control when it opens.
Old 05-12-2010, 12:26 AM   #5 (permalink)
I've found this :22R, 22RE, 22RTE Vacuum Diagrams - Pirate4x4.Com Bulletin Board Do i really need a vacuum modulator?
Increasing EGR flow for better mileage Daox EcoModding Central 232 01-26-2015 10:43 AM
Trouble Code PO401 EGR Flow Insufficient Detected Ford Man Off-Topic Tech 4 12-09-2011 12:45 PM
Metro EGR passage cleanout needed -- any tips? lyd DIY / How-to 2 09-30-2008 11:11 PM
EGR dilution for more MPG? cfg83 EcoModding Central 18 04-29-2008 09:11 PM
Adjustable EGR guitarterry EcoModding Central 1 04-27-2008 03:04 PM
