Old 10-31-2013, 07:46 AM   #11 (permalink)
Nice work.
I was reading this thread thinking I wish I could use our 3D printer here at work and
go into the grill block business.
Old 11-01-2013, 08:11 AM   #12 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
That looked quite nice on the pictures. However that is lots of work and takes skills to get smooth surface.
If you use 3mm thick ABS plastics that has etched surface you can make this kind block in a hour if you have praticed or about three hours if its your first time:
Upper block from behind...
Total looks of the car.
Beginners guide:
1. To shape the block first cut right size paper/carboard block
2. transfer the lines to ABS plastic with pen marker.
3. draw the line with sharp knife plastic on the floor. Once is enough.
4. Bent the plastic and it will break along the line
5. fit to the car and fine tune cutting off small pieces with knife. 1mm is easy but up to 3mm if you have sharp knife and right technigue.
6. mark ziptie positions with pen marker
7. drill 5mm holes
8. Make about 50mm hole for outside temperature sensor
9. Install and enjoy
I just measure and build without template and it looked like that with first try .
https://www.linkedin.com/in/vesatiainen/
Developing next gen wheels and tires which will give 20% more range in Tesla Model Y.
The Following 2 Users Say Thank You to Vekke For This Useful Post:
jedi_sol (04-11-2014), justme1969 (03-20-2014)
Old 12-03-2013, 08:18 AM   #13 (permalink)
4drtegra - '01 Acura Integra GSR
90 day: 27.39 mpg (US)
CBR600RR - '05 Honda CBR 600RR
90 day: 42.84 mpg (US)
2011 STi - '11 Subaru Impreza WRX STi
90 day: 21.28 mpg (US)
Suburban - '07 Chevrolet Suburban LTZ
90 day: 17.5 mpg (US)
Any updates to the mods and your averages?
Old 03-19-2014, 09:09 PM   #14 (permalink)
Eco of course
so the original poster:
no issues with cool down? with the radiator?
Old 03-19-2014, 09:19 PM   #15 (permalink)
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
I monitor my water temp gauge via the torque app
Normal running temp: 186*F
with grill block: it fluctuates between 188-205*F
the cooling fan on the sti does not kick in until 215*F.
No overheating issues thus far!
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
Old 03-20-2014, 10:33 AM   #16 (permalink)
justme1969's Avatar
I dont want to hijack the post but The ABS if reinforced may just be an answer for my rear wheel skirts. I want them to precision flush mount into the opening, but be easy to remove for tire failures. Cutting a few zipties is a better answer than ive been contemplating so far; and much cheaper than push pins.
Old 03-21-2014, 02:11 PM   #17 (permalink)
The Civic - '02 Honda Civic EX
90 day: 42.09 mpg (US)
Looks great! I did the same with mine last summer. I had issues when it came down to the final shaping. Luckily USC Icing does a great job of filling pinholes.
The Following User Says Thank You to Topdawg_135 For This Useful Post:
jedi_sol (03-21-2014)
Old 03-27-2014, 01:06 PM   #18 (permalink)
jedi_sol's Avatar
Subaru
Sports Cars
Team Turbocharged!
the perfectionist in me is still unsatisfied on how my upper grill block came out....its too bulky, heavy and "wrinkly."
I'm getting better at fiberglassing now and learned that the better i prep in the beginning, the better the result.
For version 3.??? i lined the outer edges of the upper grill opening with double sided tape and tightly wrapped a tshirt around the whole thing. This way i should hopefully have clean edges, no sagging, no need for expanding foam, and minimal sanding. I'm also putting on more layers of resin for strength so that it should not crack when i remove the grill block from the grill.
Old 04-11-2014, 02:57 PM   #19 (permalink)
jedi_sol's Avatar
Subaru
Sports Cars
Team Turbocharged!
updates
Resin came out pretty smooth, I shouldn’t need to sand it that much
I also bought myself a rotary/dremel too (my first power tool!) to let me get some really nice details around the Subaru emblem.
Old 04-11-2014, 03:44 PM   #20 (permalink)
Looks good. If you want to make it really smooth spray a guide coat (super thin layer of a different color) on it and sand it down to see your high/low spots. Fill in the low spots with some body filler.
