Old 01-22-2020, 12:42 PM   #1 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Janky tools you made that worked
A thread for the odd-ball tools you have made that did the job correctly and permanently and also those that were for a good enough fix to get to work.
I submit this example in the category of tools that got the job done correctly without needing to redo anything. Replacing my distributor, I needed to know when the cylinder number one was in top dead center on the compression stroke. Doing the screwdriver trick only tells you when the piston is at the top. Using this tool told me when I was in the compression stroke at the top. It is made out of a zip tie, the index finger from a used disposable latex glove, and the empty sleeve from a JB Weld Steel Stick container. It did not seal perfectly on top of the spark plug hole. But it sealed well enough that the glove finger would inflate a little on the compression stroke allowing me to know when I was approaching TDC. Then I would use the screwdriver method to determine precise top dead center. Car runs great. (Keeping the "tool.)
The Following 2 Users Say Thank You to California98Civic For This Useful Post:
Gasoline Fumes (01-22-2020), redpoint5 (01-22-2020)
Old 01-22-2020, 02:16 PM   #2 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
I made a window crank clip remover out of something I found on the ground at a junkyard. Worked so well that I still have it in my tool box!
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
Xist (01-23-2020)
Old 01-22-2020, 03:46 PM   #3 (permalink)
Cyborg ECU
Oh yeah. I made and kept one of those, too. For my Civic. Got a photo? I can find mine and photograph it after work.
Old 01-22-2020, 04:36 PM   #4 (permalink)
90 day: 29.78 mpg (US)
My dad needed to cut a hole in the roof to install the exhaust vent for a tankless gas water heater. The problem was there were multiple layers of "roof" and we didn't have a drill bit long enough to go through all. I suggested we get a center point for the holes by shooting a hole through the roof.
I've got a video of my dad holding a gun with a couple bubble levels on the barrel and shooting a hole through the ceiling.
The Following 5 Users Say Thank You to redpoint5 For This Useful Post:
Daschicken (01-23-2020), Ecky (06-13-2021), freebeard (01-24-2020), roosterk0031 (01-22-2020), Xist (01-23-2020)
Old 01-22-2020, 08:40 PM   #5 (permalink)
I built my own tig welder out of an old junky welder.
Yeah I have stuck a level on a rifle shot a hole through a roof to follow the hole through the ceiling and shingles before to install a vent.
The Following 2 Users Say Thank You to oil pan 4 For This Useful Post:
redpoint5 (01-23-2020), Xist (01-23-2020)
Old 01-22-2020, 09:27 PM   #6 (permalink)
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
My brothers eclipse (2.4 v6 I think) uses a special tool for the timing belt tensioner. It was just a plate with 2 pins and a square drive hole. Instead of ordering it and waiting we ran to the local metal warehouse, found some rod the correct size and I welded the pins on some plate stock and welded a bolt on as well. We just used a torque wrench (per the procedure) on the bolt and voila! Job done.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
The Following User Says Thank You to M_a_t_t For This Useful Post:
Xist (01-23-2020)
Old 01-23-2020, 01:54 AM   #7 (permalink)
Cyborg ECU
Window crank clip removal tool
Made from a paper clip, of course.
Xist (01-23-2020)
Old 01-23-2020, 11:27 AM   #8 (permalink)
EcoModding flying lizard
Daschicken's Avatar
Cibbie - '88 Honda CBR 250R
Motorcycle
90 day: 48.49 mpg (US)
Rarity - '06 Honda Accord EX V6
90 day: 29.88 mpg (US)
Baby viff - '86 Honda VFR 400R
Motorcycle
90 day: 42.15 mpg (US)
Latios - '08 Suzuki SV650SF
Motorcycle
90 day: 64.56 mpg (US)
Mazda 3 - '14 Mazda 3 i Sport
90 day: 43.25 mpg (US)
Cam chain tensioner release/hold(?) tool for a CRF250R. Cut out of sheet metal. Looks like a miniature key without any bitting.
Sounds fun, how did you catch it at the other end? Please tell me it was caught.
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
You can lead a fashion-conscious horse to unusual-looking water...
The Following User Says Thank You to Daschicken For This Useful Post:
Xist (01-23-2020)
Old 01-23-2020, 12:51 PM   #9 (permalink)
Saw the same technique on "Alaskan Bush People". A block of wood on the roof might suffice to stop the bullet. Subsonic .22 LR ammo would be my preference. A store that sells equipment to electricians would likely have long drill bits.
Old 01-23-2020, 01:10 PM   #10 (permalink)
When installing a whole house vacuum system, they often cut a coat hanger at an angle and use that to drill through the floor, but where is the fun in that?
Does my text look small to you?
