Old 10-06-2013, 12:18 PM   #1 (permalink)
Black sheep 2013 - '11 Volkswagen Jetta S
90 day: 29.01 mpg (US)
black sheep 2014 - '11 volkswagen jetta trendline plus
90 day: 29.78 mpg (US)
Black sheep 2015 - '11 Vw Jetta mk6
90 day: 22.42 mpg (US)
full belly pan good or bad
i would love to add a full belly pan to the bottom of my car, are there any parts under there that should always be air cooled or can i just cover the whole thing up ? my main convern would be the exhaust heating up. and what about just the back half being covered by cloroplast and not the front half.
Old 10-06-2013, 01:10 PM   #2 (permalink)
Hydrogen > EV
Silver Flea - '05 Honda Insight
90 day: 58.96 mpg (US)
I'd be worried about chloroplast decomposing. The heat may make it catch on fire if it gets too hot and too dry.
Every vehicle is different. I first started by making a simple design that would easily come off if something went wrong, it was weakly attached, and easy to get to from the dirt on the side of the road. I also started in stages, first the front, then middle, then rear.
I would not advise starting at the rear, since if it is sealed, it may act like a parachute when air moves above the belly pan. Sealing it upwards seems like a lot of extra work compared to just starting from the front.
I would advise using polycarbonate (election sign material, basically thin plastic in the same design as cardboard).
These threads may help you develop a plan more so, often as we who have done it forget lots of things from when we make threads, and go into great detail- you may learn things there that we forget to bring up now.
belly pan - Google Search
or
underbody - Google Search
Look forward to following your build.
Best Tanks:
Mustang - 54.83 mpg (US) at the Green Grand Prix
Insight - 82.91966 mpg (US) over 818.5 miles.
Old 10-07-2013, 12:24 PM   #3 (permalink)
Excuse if I'm mistaken, but I'm pretty sure what you are talking about here is coroplast. Polycarbonate(aka Lexan) is what eyeglass lenses and some motorcycle helmet faceshields are made of. I believe if you search some of the build posts that many folks on here have used coroplast for belly pans and they talk about how to deal with the hot spots under the car.
JJ
Old 10-07-2013, 12:36 PM   #4 (permalink)
Hydrogen > EV
https://www.google.com/#q=cloroplast
Chloroplast - Wikipedia, the free encyclopedia
Coroplast is a name brand, just like Lexan, and others. I think the generic name is "corrugated plastic," I've always referred to it as poly carbonate, I am not sure if that is the technical name- but chloroplast is a part of a plant lol
Best Tanks:
Old 10-07-2013, 12:49 PM   #5 (permalink)
fuel conserver
Civic - '99 Honda Civic EX
My guess on this is that the underbody becomes less important to be smooth if you put a lower air dam on the car to make air go around the car instead of forcing it underneath.
'02 E-350 7.3 Diesel (Work Van)
'91.5 Cummins 4x4 (Old Blue)
'00 Jetta TDI 5spd
'22 Tundra TRD OR
'04 RX330
'05 Tacoma 4x4
Old 10-07-2013, 01:06 PM   #6 (permalink)
Correct.
Polycarbonate is a material--generally a relatively hard plastic and most often clear.
The coroplast that most people on this forum refer to is normally made from polypropylene.
However after reading a bit more, I have found that corrugated plastic sheets can and are also made using polycarbonate.Yay, got to learn something today. My guess is that they would be a bit more expensive though as polycarbonate is not normally cheap. I believe polycarbonate has better UV resistance too although that might not matter beneath a car.
Thanks for teaching me something new UltraArc.
JJ
Old 10-07-2013, 01:51 PM   #7 (permalink)
cbaber's Avatar
Lean and Mean - '98 Honda Civic HX
90 day: 46.69 mpg (US)
That is true, but the ideal solution is a smooth belly pan front to rear. An air dam increases the frontal area of the vehicle. If it does divert air away from under the car it can increase efficiency, but a full belly pan will be more efficient.
1998 Honda Civic HX - My Project Thread
The Following 2 Users Say Thank You to cbaber For This Useful Post:
E.Roy (10-08-2013), UltArc (10-07-2013)
Old 10-07-2013, 02:48 PM   #8 (permalink)
90 day: 30.18 mpg (US)
Once we get everyone to spell coroplast correctly, will we try to get them to pluralize appropriately?
Old 10-08-2013, 04:55 AM   #9 (permalink)
fuel conserver
Well said, I forgot about frontal area. Thank you for clarifying!
'00 Jetta TDI 5spd
'22 Tundra TRD OR
'04 RX330
'05 Tacoma 4x4
Old 10-08-2013, 06:53 AM   #10 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
The idea is to combine both.
The air dam extending down to the lowest point on the chassis, which would determine the frontal area anyway, to divert as much air around the car as possible.
The belly pan mounted on the lowest point of the chassis smooths out whatever air still goes underneath the car.
belly, pan
