Old 04-23-2008, 11:34 AM   #1 (permalink)
Green Rodder
Grease Beast - '92 Dodge D250 Standard
Econo-Beater DX - '92 Toyota Corolla DX
How get a shorter belt........
How does one get a shorter belt? In this case a serpentine. The easiest way is to get a belt from a truck that doesn't have a/c. But if I wanted an even shorter belt I could measure it. But I can't imagine the local parts guy (even though I know him) would be completely happy with me if I said "I need a belt that is 42" long".
I probably could run nothing at all since the injection pump and the power steering/vacuum pump combo are gear driven.
The power steering with the piggyback'd vacuum pump combo could probably be replaced with an electric vacuum pump and the power steering could theoretically be replaced with an electric pump but I need a real heavy duty unit.
I need to try out different combos of a/c and alt. for mpg reasons and for a standing mile run later on this year.
I'm already planning to ditch the fan and water pump with electric versions
Any clever ideas on the belt situation? Cummins 5.9 12v diesel
Old 04-23-2008, 11:50 AM   #2 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
How I do it is.
Cut your existing belt, Hold your tensioner about where it need to be (or a little looser). Then keep cutting little bits off until you have the length you need, measure, purchase.
Or you could just buy several and return the unused ones.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 04-23-2008, 12:09 PM   #3 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
You should go to your local industrial power transmission distributor (such as motion industries in the US, or Kinecor in Canada) with the specs of the belt you need. They'll find something that fits for sure.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 04-23-2008, 08:51 PM   #4 (permalink)
Since your engine is most likely one in a "family" maybe a belt from another application of that engine will be suitable.
Marine engine , stationary generator , water pump or something like that.
Pete.
Old 04-23-2008, 11:13 PM   #5 (permalink)
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
local parts guy sure does have belt catalogs by lenght, width etc.
Accord Timing Belt Who Off-Topic Tech 9 02-29-2008 11:39 AM
Removing components off engine belt. NoCO2 EcoModding Central 15 02-11-2008 04:52 PM
