Old 10-14-2015, 05:55 AM   #11 (permalink)
wdb
lurker's apprentice
PlainJane - '12 Toyota Tacoma Base 4WD Access Cab
90 day: 20.98 mpg (US)
Originally Posted by markweatherill View Post
Try it with the engine running. You may see a difference!
Originally Posted by Cd View Post
How do you do that ?
Indeed! An extra spark plug perhaps.
Old 10-14-2015, 10:51 AM   #12 (permalink)
Send a message via MSN to markweatherill
You remove one spark plug, lay it on the engine or hold it there (carefully)somehow so it has good ground connection, start the engine and run it, long enough to see what the spark is like. I'm sure there are videos on Youtube that explain it better.
Alternatively, there's a device called a Gunson Colortune, I had one years ago.
Old 10-14-2015, 03:53 PM   #13 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Close the gap on all the spark plugs by .02-.04 (depending on what stock is supposed to be). On my Fox (prior to going forced induction) I went from the .54 that was stock down to .50. It seemed to have better throttle response at higher rpm ranges. I run .34 now due to FI.
Old 10-14-2015, 05:09 PM   #14 (permalink)
Cd
Ultimate Fail
Cd's Avatar
I tested the spark this way, but never let the car actually run more than a second.
It shudders and kicks, and sounds awful, so I always shut it down if it does happen to start on just 3cyls.
Surely running the car on 3cyl is bad for the car !
