Old 06-11-2014, 03:06 PM   #31 (permalink)
ALL UP ON THE INTERWEB!!!
vrmouseyd15b's Avatar
skidmark - super snail - '89 honda civic wagon WAGOVAN
Team "Old SKOOL"
90 day: 30.87 mpg (US)
Pituca - '19 Honda Insight Touring
90 day: 39.34 mpg (US)
Originally Posted by ecomodded View Post
I will suggest you use a fine rat tail file and file the ground surface until its completely square and flat.
I used a hand file and square to go over my grinder cut bushings when i had to cut some bushings down for a lift kit Control arm install that did on my old 4x4. I got them square by filing them by hand in a vice.
I like the hand file idea, for now I'm trying to talk to my buddy and see what it would cost to have these babies machined at his work.
worst come to worst, the file will be my best friend!
Old 06-11-2014, 06:30 PM   #32 (permalink)
Thats how you see a ball vanish from a ball bearing. A piece of metal gets stuck in a race and the ball wears away.
I cant say my honda suffers from much wheel spin if at all. Not something Id rush out to do either. Better tires, psi adjustment, etc is what you need.
I use to be able to do burn outs with my sidekick with the stock size centennial S(P?)tires. Since I went up 3 sizes to better tires it chirps and grips hauling ass.
Old 06-11-2014, 07:02 PM   #33 (permalink)
Drive less save more
ecomodded's Avatar
90 day: 60.42 mpg (US)
Being that the limited slip block is made from aluminum if anything will wear it will be it and its filings will be soft aluminum. I believe its just CNC aluminum so ( I think) it is the weakest link / sacrificial metal. The gear needs to be true or it could rub and eat the aluminum in short order.
Save gas
Old 06-11-2014, 08:34 PM   #34 (permalink)
Team "Old SKOOL"
All true, my man.
Old 06-11-2014, 10:36 PM   #35 (permalink)
clank - '99 jeep tj sport
90 day: 17.32 mpg (US)
it looks like a copy of these guys
Honda Limited Slip, Honda Limited slip differentials, Limited Slip Differentials,
Old 06-11-2014, 10:43 PM   #36 (permalink)
Team "Old SKOOL"
Yup. That's what gave me the idea. I just got a less expensive one (the ALDI ONE! )
Old 06-11-2014, 11:52 PM   #37 (permalink)
"Improve traction and safety, Increase 60' times at the strip, Corner faster, Tow easier, Eliminate torque steer with both wheels working together."
Old 06-11-2014, 11:54 PM   #38 (permalink)
Team "Old SKOOL"
Chicks dig it
