Old 09-19-2015, 09:48 AM   #1 (permalink)
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
How To: Kill switch, 02 TDI Jetta
rigged to fuel cutoff solenoid valve, located on top of IP. it's just a switch to short circuit the electrical feed line, not allowing fuel to pass, thus killing engine.
no wires cut, to go stock if wanted.
......original wire is connected to new wire with small bolt, heat shrink with double wall tubing(water proof).
fed through engine compartment, zip tied, fed down to door opening.
ran wires to cabin, through grommet, under dash, to shifter.
**pic to follow**
zip tied to shifter for now. can build a mount from aluminum to bolt on later.
push to kill, pull to energize.
momentary switch used wasn't to my liking. didn't like to have keep pressing switch, esp while coasting, turning, braking, etc...
have left it off a few times, try to bump or key start and get a half second of a start but no more. if it was hidden would make a great theft deterrent but I look at it as who would want to, really.
next would be a starter button on shifter. that would be a momentary switch.
I will get other pics when I get a chance.
hope this wasn't a bunch of mumbo jumbo and made a little sense.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
The Following 2 Users Say Thank You to deejaaa For This Useful Post:
Daox (09-22-2015), Joggernot (09-20-2015)
Old 09-21-2015, 10:16 PM   #2 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Makes sense to me. I'll be watching your mpg. FWIW I DFCO coast in gear and E-on coast in neutral but don't bother trying to kill the engine on my glide phases.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
Old 09-21-2015, 11:14 PM   #3 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
Where does the other end of the switch go? You switch the IP contact to ground?
I'm not coasting, I'm shifting slowly.
Old 09-21-2015, 11:16 PM   #4 (permalink)
UFO
UFO's Avatar
That's what I am currently doing too. Haven't had a manual long enough to post any results, I have 150 miles on my first tank with the new transmission. I'm also not sure what the effect of having a stuttering idle because my InjectedQuantity is too low.
Old 09-22-2015, 02:03 AM   #5 (permalink)
Not banned yet
deejaaa's Avatar
created a short in the feed wire.
this is what i did:
Old 09-22-2015, 10:37 AM   #6 (permalink)
UFO
UFO's Avatar
I see, you just open the connection to the IP, that makes more sense. Thanks for posting this.
The Following User Says Thank You to UFO For This Useful Post:
deejaaa (09-22-2015)
