Old 08-21-2010, 09:11 PM   #11 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Well after 600+ miles with the upper block on, no issues at all. Just lots of looks!
Picture of my grill block fully painted:
Old 08-24-2010, 04:54 PM   #12 (permalink)
Wiki Mod
Update:
I did some steady state ABA testing today.... with a .71 MPG gain!
A=44.88
B=45.73
A2= 45.15
For this little amount of work, that is a rather large gain in my book!
These results are just from the improvement in aerodynamics. Warm up gains were not counted in that .71MPG number. I do not have good data for warm up MPG gain, I do have warm up distance numbers: no grill block miles to 180F (when thermostat opens) 5 miles, with upper grill bock it is 3 miles.
The Following User Says Thank You to Weather Spotter For This Useful Post:
Daox (08-24-2010)
Old 08-24-2010, 05:07 PM   #13 (permalink)
Thats why its the first mod I recommend! Thanks for getting numbers on it.
Old 08-24-2010, 05:21 PM   #14 (permalink)
Couldn't you keep the badge airhole and put a squirrel fan over it? That way you could run the engine super-hot with a few heaters. Also, it could potentially replace the radiator fan.
EDIT: Actually, since you live in colder weather, It's best to just forgo a squirrel fan.
Old 08-24-2010, 05:35 PM   #15 (permalink)
Wiki Mod
If you look at the before and after picts, I think it looks very bad to leave the logo open. besides I have the lower gill 100% open at this point (more plans in the works).
I will also add my data to the wiki shortly.
Old 08-24-2010, 06:31 PM   #16 (permalink)
Wiki Mod
Test data Update:
Raw data:
Graph:
2003 Toyota Matrix Block Heater Daox EcoModding Central 25 11-03-2012 08:59 AM
DIY - Front Grill Block - 1991 Honda CRX SVOboy DIY / How-to 33 06-24-2011 05:16 PM
grill "shield" rather than block? lunarhighway Aerodynamics 70 12-17-2010 03:50 AM
Too much grill block thatguitarguy Aerodynamics 14 01-12-2010 11:29 PM
Full Grille Block: Upper Grille DifferentPointofView Aerodynamics 12 02-28-2008 10:14 AM
