Old 09-09-2009, 05:58 PM   #1 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 26.69 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
How much HP and Torque can a TCC handle???
common sense tells me that they would have to be pretty durable to handle what they do for as long as they do. But I still wonder why they unlock at 90% load, is it because the car knows you want more power so it lets the rpm go up?
how much gas can i give it without damaging it in lower gears? part of the reason i ask is because cars don't generate much power at low cruising rpms. Is that why TCC don't lock up all the time in 2nd through...?
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
Old 09-09-2009, 06:15 PM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
A torque converter is able to multiply torque when there is a significant difference between input and output speeds. Torque converter - Wikipedia, the free encyclopedia
at %90 load, maybe they think you want more torque (not always true)?
Old 09-09-2009, 06:51 PM   #3 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
I think the OP is asking about the lock-up clutch.
Old 09-09-2009, 06:55 PM   #4 (permalink)
dcb
needs more cowbell
dcb's Avatar
if you unlock the torque converter, it can multiply torque, yes, inefficiently.
Old 09-09-2009, 07:11 PM   #5 (permalink)
42.
roflwaffle (09-09-2009)
Old 09-10-2009, 12:02 AM   #6 (permalink)
Team Pontiac
42 what? nt
1991 F-250:
Old 09-10-2009, 12:26 AM   #7 (permalink)
dcb
needs more cowbell
dcb's Avatar
It is the answer to everything.
http://ecomodder.com/forum/showthrea...und-10073.html
Click on the movie link, it should explain everything
Old 09-10-2009, 12:34 AM   #8 (permalink)
I wonder how much wood can a woodchuck chuck-
if a woodchuck could chuck wood?
Is it 42?
Old 09-10-2009, 12:35 AM   #9 (permalink)
Team Pontiac
must be
1991 F-250:
Old 09-10-2009, 12:40 AM   #10 (permalink)
Good. Now I will be able to get a good night's sleep.
Minimum HP requirement superchow General Efficiency Discussion 16 08-26-2009 10:29 PM
