Old 08-19-2015, 12:15 AM   #1 (permalink)
How to tighten difficult-to access bolts?
I hope to nearly be finished replacing the head gasket in my Forester. I changed out the head gasket a while ago, put the timing belt back on, as well as all of the sprockets, pulleys, and covers, and then the intake manifold and radiator. I kept trying to remember what I needed to remove in opposite order.
It was the AC compressor and the intake manifold.
Everybody said to remove them in that order, but one bolt is awkward:
I just need to use a wrench instead of a socket, but when I go to tighten it, it gets too tight too early; if I had more room, I could torque it down, but I already sheared two bolts and stripped one hole, no more!
Notice the lock-tite red? Obviously that stuff needs to come off, and then it should be okay.
However:
I can barely reach a finger in from each side to position and start tightening, there is no possible way that I could fit a wrench in there.
Is there some special tool that would do the job, or do I need to remove and detach the intake manifold again?
Thank you very much! Please enjoy your day!
Name:	AC compressor bolt 1.jpg
ID:	18456   Click image for larger version
Name:	AC compressor bolt 2.jpg
Old 08-19-2015, 12:35 AM   #2 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
I hate to say it, but if it's getting tight when it's that far away from the surface, it's probably cross-threaded....
UIUC Aerospace Engineering
www.amateuraerodynamics.com
Old 08-19-2015, 12:41 AM   #3 (permalink)
I removed it and it was very dirty. Dried lock-tite and children's crushed dreams, apparently.
Old 08-19-2015, 12:42 AM   #4 (permalink)
Or you've mixed up the bolts, and have one that's too long for its hole. (Been there, done that :-()
Old 08-19-2015, 02:14 AM   #5 (permalink)
James, that sounds like a terrible prospect! I will double-check, but both the hole and that bolt had lock-tite red on it.
Old 08-19-2015, 12:55 PM   #6 (permalink)
darcane's Avatar
Assuming it's the right bolt and not cross-threaded....
Can you get in there with a long extension, a wobbly, and a short socket?
http://www.sears.com/craftsman-3-pc-...&blockType=G11
If the wobbly is too wobbly, wrap the joint in electrical tape and it will wobble less and be easier to get over the head of the screw.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
The Following User Says Thank You to darcane For This Useful Post:
Xist (08-19-2015)
Old 08-19-2015, 05:26 PM   #7 (permalink)
Back the bolt out and check the depth of the hole.
regards
mech
Old 08-19-2015, 05:29 PM   #8 (permalink)
Most modern engine repairs begin with R&R engine. In a 93 ZX they do that to replace the knock sensor.
regards
mech
Old 08-19-2015, 05:31 PM   #9 (permalink)
On the old Toyota Previa you R&R the engine to do the 60k service, or at least that is what I thought I read about them.
regards
mech
Old 08-19-2015, 05:51 PM   #10 (permalink)
And on the new f250 diesels you pull the cab to service the engine. Even had quick disconnects
