Old 07-01-2009, 12:35 PM   #1 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
How to use scanguage to accellerate? Which guages?
I finally broke down and bought a $124 scanguage from JCWhitney.
I know that accelleration is a tough one but since I now drive mostly city and rarely highway (opposite of my former life) I can't figure out how to bloody accellerate without terrible FE.
Anyway the 3 vehicles that I usually end up with (depending on what the other folks here are doing) are a
1. 2002 TDI Jetta 4sp auto
2. 1998 3.8Buick 4sp auto
3. 2001 Dodge Ram crew 5.2 auto
(I love to drive electric but since I drive much less now the electrics are usually out and about without me
I have figured out the dodge mostly, I just accellerate harder than normal to get to speed than coast and carefully monitor the throttle to keep high fe, this one is the easiest to improve I can defiantely see how hard I can push before MPGs drop.
The buick is a little tougher but it seems like again push harder than normal, let off to coax a shift, push harder than normal, repeat. Once up to 3rd I gradually let off the accelerator during accelleration and the MPGs actually move up rapidly as compared to the low gears that stay terrible all the time.
Now the one I don't Get the 02 TDI jetta seems to be impossible to accellerate, my mileage is always in the dumps even SLIGHT accelleration causes the MPGs to drop in half, the harder I accelerate the worse the FE but any accelleration cuts FE in half. Low gears cut FE in half. Its like a rock and a hard place I just can't get the car up to speed without a huge FE hit and I don't drive long enough stretches to get FE up.
Any ideas what guages or x-guages might help me make heads or tails as to how to drive these in town? I just can't seem to figure out a pattern or method to accellerate without having very low mpg's. In other words with or without the guage at least in town I haven't been able to improve FE significantly, although for long trips its worked wonders, I should have had one of these years ago.
I know about coasting, the sad part is the Jetta coasts about as far while DOWNSHIFTING as it does in Neutral which is not very far. These blasted autos coast like a brick without wheels.
THank You
Ryan
Old 07-01-2009, 04:59 PM   #2 (permalink)
chuckm's Avatar
Exploder - '02 Ford Explorer xlt
Rolla - '02 Toyota Corolla ce
90 day: 44.43 mpg (US)
I'd hazard a guess that LOD would be a good choice.
"Jesus didn't bring 'Natty Lite' to the party. He brought the good stuff."
Old 07-01-2009, 05:13 PM   #3 (permalink)
IMO autos are tricky. Its easy to pin LOD where ever you want with a manual trans, but with an auto you have to learn to balance things. You don't want to loose a ton through the torque converter by loading it up too much. But, you don't want to loose a ton to pumping losses either. You really just gotta play with it until you find what you think works best. Using LOD should definitely help with that.
Old 07-01-2009, 05:40 PM   #4 (permalink)
Matt Herring's Avatar
Bone's 2010 Prius - '10 Toyota Prius Black
90 day: 56.78 mpg (US)
I'd also use LOD as one of the 4 guages to monitor. For the other 3 it's really a preference and you might end up using different guages for different vehicles depending on how they feel to you. MPG is an obvious one as you need to see that live to know where your sweet spots are. If your cars don't have an RPM guage then RPM is a good one to monitor as well. I never accelerate past 2000-2100 RPM unless I'm straight uphill and have to do it to keep up to speed.
For acceleration, the SGII is going to be invaluable to you. When I first got my SGII I tended to baby the acceleration because I didn't want to peg the RPM but I found that moderate acceleration to get it past the first couple "gears" in the automatic and up to 30-35 mph was best for FE. When I started doing that I was able to use P&G more often in my commute and saved alot more fuel than dragging up to 30-35 mph.
Old 07-02-2009, 10:14 AM   #5 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
How did you get it for $124?
Old 07-02-2009, 01:48 PM   #6 (permalink)
rmay635703's Avatar
Actually it was $127.XX they have/had a 20% off and free shipping coupon for JCWhitney.com online orders, just lookup JC Whitney 20% off coupon and you should eventually find the coupon code.
I figured out the Jetta, I finally took the diesel on the highway and it says I am getting 27mpg which means the Scanguage is WAAY off, I had it set for Diesel A, Diesel B ended up worse accuracy wise (not to mention the throttle doesn't go up like diesel b anyway). The funny part is I can sustain around 46mpg per the scanguage in town at lower speeds but at highway speeds its always around 27mpg which is very very wrong.
Not sure how I correct/tweak very very inaccurate readings with the Scanguage on my Volkswagon Diesel.
The Buick was quite accurate out of the box, Dodge was very close but apparently the SG doesn't like diesels much.
Sad part is if I do a lot of tweaking I will need a way to reset the SG often as I move it from vehicle to vehicle often; as the other drivers won't use or look at it.
Cheers
Ryan
Old 07-02-2009, 01:59 PM   #7 (permalink)
Your best bet would be to use the SGII for a couple tanks in a row in one vehicle and then record the % adjustment for that car before moving the SGII to another vehicle and repeating the process. After a few tanks in each car you will have your % adjustment for each vehicle and you can plug that in when you move the SGII from vehicle to vehicle.
There is a thread on ecomodder where guys have posted their % adjustment for their cars so maybe you can find your cars in that thread and use their % adjustment values if you don't know what they are already.
Old 07-02-2009, 02:02 PM   #8 (permalink)
Hypermiler
Wagons
Common problem with SG and diesel. Not much to do about it, unfortunately.
Thanks for the coupon idea.
Old 07-02-2009, 02:11 PM   #9 (permalink)
Yeah, the SG assumes you're in closed loop all the time. It has no way of accounting for different air/fuel ratios unfortunately.
Old 07-02-2009, 02:20 PM   #10 (permalink)
Hypermiler
Wagons
I'd advise learning from the SG on the other vehicles, and then applying the same to the TDI. That'll get you close.
ScanGuage not accurate on HEMI MDS Harpo Hypermiling / EcoDriver's Ed 3 12-21-2014 05:09 PM
Driving the Scanguage for FE Harry6 Hypermiling / EcoDriver's Ed 12 04-02-2010 12:51 PM
scanguage vs. garage scan tool? MazdaMatt Instrumentation 3 02-26-2009 06:01 PM
Trouble w/ Scanguage... 97Cavalier Instrumentation 7 09-15-2008 12:35 PM
Scanguage users - accuracy question Formula413 Instrumentation 7 08-26-2008 04:55 PM
