Old 01-31-2014, 02:29 PM   #21 (permalink)
darcane's Avatar
Okay, but which would you recommend more, an MPGuino, or an Ultraguage?
Well, I personally use the Ultragauge and I'm quite happy with it. I've never used an MPGuino.
It really depends on what you need. If you are fine with a little inaccuracy when it goes into lean-burn, the Ultragauge is great. If you feel you need the accuracy with lean-burn, MPGuino is the only choice.
MPGuino requires that you tap into your VSS and fuel injector circuits, plus a positive and ground. Ultragauge simply plugs into the OBDII port and you are done.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
