Old 07-24-2009, 04:14 PM   #1 (permalink)
My Goal: 35 MPG All Day
RandomFact314's Avatar
1NZ-FE (Year 1) - '05 Scion xA RS 2.0
Last 3: 34.02 mpg (US)
1NZ-FE (Year 2) - '05 Scion xA RS 2.0
90 day: 33.32 mpg (US)
1NZ-FE (Year 3) - '05 Scion xA RS 2.0
90 day: 35.32 mpg (US)
1NZ-FE (Year 4) - '05 Scion xA RS 2.0
90 day: 34 mpg (US)
1NZ-FE (Year 5) - '05 Scion xA RS 2.0
90 day: 26.87 mpg (US)
1NZ-FE (Years 6,7,8) - '05 Scion xA RS 2.0
90 day: 28.6 mpg (US)
1NZ-FE (Years 9,10,11) - '05 Scion xA RS 2.0
90 day: 27.8 mpg (US)
1NZ-FE (Years 12,13,14) - '05 Scion xA RS 2.0
90 day: 27.11 mpg (US)
LRR Viva 2 tire results
Tires Before: (All tires are 185/65/14, even the new ones)
FRONT:
Goodyear integrity (25-35psi) no tread, leak (44max psi)
Goodyear integrity (20-35psi) no tread, rapid leak (44max psi)
REAR:
Radial classic (35psi) no tread
Radial LTE Futura 2000 (35psi) no tread (44max psi)
Tires NOW:
FRONT:
Goodyear Viva 2 (44psi) ~LRR
REAR:
*Rear is same as before*
***And now these are my last 3 results (I'm only showing the last 3 because they are with the same weather, And I removed the one that was all highway)
Before:
30.36
30.53
30.83
After Replacing the front 2 tires:
31.34
Old 07-24-2009, 04:16 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
I demand ABA!
Old 07-24-2009, 05:58 PM   #3 (permalink)
90 day: 34 mpg (US)
Originally Posted by SVOboy View Post
I demand ABA!
I don't have the old tires anymore, And I defiantly could not un-mount, mount, un-mount, and remount them over and over anyways.
Old 07-24-2009, 06:24 PM   #4 (permalink)
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
I think he's pulling your rubber leg.
Or perhaps it's a typo. SVOboy demands ABBA?
LRR is the bomb! I bought my new "HRR" before I knew LRR were readily available.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
Old 07-27-2009, 01:04 AM   #5 (permalink)
90 day: 34 mpg (US)
So if I were to just guess (not that I completely think this) they gave me +1mpg, if I changed the 2 back tires to the same tires would I get another 1mpg or would it be less since they are back tires and not doing much?
Old 07-27-2009, 01:06 PM   #6 (permalink)
Civic 4 Life
KJSatz's Avatar
Civics Lesson - '08 Honda Civic LX
90 day: 40.53 mpg (US)
Wild speculation:
The back tires are doing much. They support roughly half of the weight, and there is plenty of rolling resistance generated back there. +1 mpg, perhaps not, but gains? Probably.
Old 07-28-2009, 10:02 AM   #7 (permalink)
The Crimson Crawler - '04 Hyundai Elantra GLS
90 day: 36.71 mpg (US)
I agree on the Viva 2's...replaced rears on my Lumina (Deltas w/no tread to Viva 2's) and saw 1.5 MPG.
Give 'em about 1200 miles to 'break in,' and they'll feel less squishy as the releasing compound works out of them.
Old 08-01-2009, 08:19 PM   #8 (permalink)
90 day: 34 mpg (US)
Oh really?! cool, they seem a little "squishy" during braking but I didn't know what that was.
Old 08-03-2009, 07:54 AM   #9 (permalink)
During braking and heavy cornering, I bet - you'll feel more than normal body roll and "sloshing" - as if you are driving on a waterbed.
You can accelerate the "break-in" by wetting them down, giving them a light scrub, and rinsing again, but may as well save the water and just drive 'em.
Old 08-05-2009, 04:48 PM   #10 (permalink)
90 day: 34 mpg (US)
So why exactly do they do the "squishy" thing? its a chemical in the tire? Explain please
Hyperinflating tires CapriRacer Hypermiling / EcoDriver's Ed 276 03-14-2022 03:51 AM
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 01:17 PM
Tire Engineer here - concerned about hyperinflating tires CapriRacer Introductions 48 09-26-2009 09:25 PM
Tire pressure and fuel economy RESULTS 07b2300 EcoModding Central 56 10-31-2008 12:40 PM
