Old 10-05-2015, 11:33 AM   #1 (permalink)
Tinkerer
kafer65's Avatar
Silver - '15 Mazda CX-5 Sport
Team Mazda
90 day: 37.23 mpg (US)
Blackout or leave raw-Mazda CX-5 skirt brace
I can't decide which would be better. Do I leave the skirt brace raw aluminum or black it out to conform to the rest of the trim style? I painted the brackets with hard bed liner from rattle can in the back. It give a decent wrinkled finish that would be close to the arch style. What do you guy think?
Mirror deletes, 80% grill blocks, wheel covers, 50 psi tires = 6% better MPG avg. over a year. Wheel skirts overcoming ethanol winter fuel mpg losses and more!
http://ecomodder.com/forum/showthrea...ead-30641.html
Old 10-05-2015, 01:25 PM   #2 (permalink)
Got MPG?
The Car - '09 Toyota Corolla CE Enhanced
I vote black for a more finished look.
It's interesting to see the clear wheel skirt, has it become more dirty on the inside over time?
2013 Honda Civic Si - 2.4L
OEM front to back belly pan from the factory.
Old 10-05-2015, 02:00 PM   #3 (permalink)
I say that you paint or plasti-dip it to match the tire, but leave the part over your rim bare.
Fat Charlie (10-06-2015)
Old 10-05-2015, 02:53 PM   #4 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Match the car's paint.
The Following User Says Thank You to euromodder For This Useful Post:
Old 10-05-2015, 05:52 PM   #5 (permalink)
Tinkerer
kafer65's Avatar
Team Mazda
It gets dirty almost instantly when raining. The wheel covers are gradually dirty over about a month if it's not raining much.
Old 10-05-2015, 06:58 PM   #6 (permalink)
Wheel skirt wipers?
The Following 2 Users Say Thank You to Xist For This Useful Post:
brucepick (11-05-2015), Fat Charlie (10-06-2015)
Old 10-05-2015, 07:10 PM   #7 (permalink)
PSmodder lurker
Always liked zoom-zoom design. Body color paint. http://i.imgur.com/r81SOZ0.jpg
Old 10-06-2015, 08:32 AM   #8 (permalink)
Joggernot's Avatar
I vote for the whole thing black.
Old 10-06-2015, 09:03 AM   #9 (permalink)
Ditto. Blackout is my vote.
Old 10-06-2015, 09:48 AM   #10 (permalink)
Tinkerer
kafer65's Avatar
Team Mazda
Better?
Its much easier to put the brackets on first to be able to see through the material to line up to the complex fender curves to drill and mount from top to bottom. The lip depth changes a lot so most of the brackets are sized specifically for a certain location. They slide onto the lip near where the plastic lip is mounted to the car to reduce vibrations and sag. I'll need to modify the brackets for a set screw since I've already had FAIL on the front skirts sliding in unison into the well after catching on the tire. There isn't any room to have a bolt and nut clamp setup.
