Old 05-07-2015, 11:43 AM   #21 (permalink)
You could do what the speaker builders do, build a wire or thin wood frame and stretch felt over the frame then glass it. Depending on how heavy your frame is, this could be a lighter alternative that allows for more aerodynamic shapes.
I've built a few speaker boxes this way and am considering this technique to build a similar trailer for behind my Focus.
I don't have the post count yet to post links or videos so search Youtube for "How to build a Fiberglass Subwoofer enclosure"
Old 05-07-2015, 02:13 PM   #22 (permalink)
Del Slow - '94 Honda Del Sol Vx
90 day: 42.31 mpg (US)
Not sure yet on how to go about the the build. I was think of plywood skeleton with aluminum skin a was also thinking of steel frame with aluminum skin trying to barrow a roller from a friend I will have to make die set to roll angle
Here is me recent purchase
The Following User Says Thank You to wagonef8 For This Useful Post:
aerohead (05-07-2015)
