07-17-2024, 06:35 PM
#31 (permalink)
The price is for a finished piece, shipped to my door. Here's a screenshot to their ad. It's hard to tell with AliExpress vendors.
07-17-2024, 07:14 PM
#32 (permalink)
screw on hubcabs. light year zero
The Following 2 Users Say Thank You to Phase For This Useful Post:
07-17-2024, 08:14 PM
#33 (permalink)
There can be no way at that price it can be true CF, I hope for your sake I am wrong, but it may meet your needs 100% anyway so good luck,
07-18-2024, 12:24 AM
#34 (permalink)
My next question, how big do I make them? 280? 305? 370?
07-18-2024, 01:08 AM
#35 (permalink)
Too many cars
I think I would aim for them to fit just inside the outer lip of the wheel. Unless you think you want them smaller to allow for brake cooling.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
07-18-2024, 01:11 AM
#36 (permalink)
Too many cars
The wheels do have conical lug seats, rather than the typical Honda ball seats.
How do the plastic caps work to hold on the wheel covers, and where can I get them?
EDIT: I see the caps have a lip, and it appears that snugs up against the wheel covers and pulls them against the wheel. Clever, but I'd need to be careful about the height of the lug caps.
The caps snap onto the wheel covers, so they don't fall off when you loosen them.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
07-18-2024, 11:27 AM
#37 (permalink)
' brakes to breathe '
Looking for some ideas on smooth wheel covers. The pics attached show the wheels I'd like to cover, and preferably not drill into or damage, as that would likely not pass an inspecton.
The rim of the wheel is at approximately flush with the hub in the center. The spokes are convex. Anything that sits flat on the lip at the edge, will likely sit flat on the hub center as well.
One idea I've had for an aesthetic attachment point, is to use "spike" lug nuts, and remove the spike, so I have something threaded to bolt onto.
I'm uncertain what material to use. I'd like the finished product to look as professional as possible. One idea I have is to use moon discs, and drill 4 holes in a lug pattern to attach them to spiked lug nuts. I could also (instead) get a flat aluminum disc, and possibly paint it or put a Honda logo on it. A third option is some kind of clear disc, polycabonate or similar. Ideally I'd keep weight to a minimum.
For edge-to-edge fitment with no air gap, I'd need something 14.5 inches or 370mm in diameter. If I wanted something that still allowed the brakes to breathe a bit, I could reasonably go as small as 330mm or 13.0 inches.
Ideas?
You might take a look at the 1992 GM 'Ultralite' concept car. Like the Miata, it's an ICE car, with no regen, and in a worse-case-scenario, might 'need' some wheel cover 'ventilation' to protect the brakes from warpage.
GM located their 'breathing' perforations immediately adjacent to the rim.
Those 'un-used' , extra four holes on the wheels, between the chamfered lug holes might give you an extra option for some 'attachment'?
07-18-2024, 08:35 PM
#38 (permalink)
Going to give the carbon fiber discs a shot, 280mm, so not out to the wheel edge, but covers the center drum and doesn't need a notch for the valve stem. Partially this is to keep the shipping and materials cost down, partially for weight (and concerns about the material holding together). I've also found some 38mm tall lug nuts that are threaded all the way through, and purchased some M12x1.5 12mm black anodized allen screws, along with some washers. Might be a few weeks for arrival. Will update with pics once it arrives.
07-18-2024, 08:44 PM
#39 (permalink)
How ya doing on the Insight?
..Without freedom of speech we wouldn't know who all the idiots are. -- anonymous poster
..I before E, except after C -- trust the Science
07-18-2024, 11:32 PM
#40 (permalink)
Just waiting for it to be ready to be picked up. It's at the body shop and last I heard they had primer on it. Could be next week, could be several weeks, they're not hurrying.
