07-08-2010, 03:48 AM
Smeghead
if I am 50% over in my car should that carry over to another?
I am currently getting in the neighorhood of 50% over EPA in my 95 honda civic. When I hypermile I get in the 50-55mpg range (some trips are a lot higher some are a bit lower depending on elevation change mostly)
EPA says the car should get 36mpg combined. When I don't hypermile I get in 38-42 mpg range on my commute which is about 40 miles round trip mostly in 45mpg area with one 55mpg stretch about 2 miles long.
Is it a good guess that given a newerish car with similar EPA guestimate, similar mods (kill switch mostly), and a manual transmition that I am likely to stay in the same Mileage range?
If I were to find a "ventage" insight how much over the EPA SWAG would I be looking at?
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
07-08-2010, 07:17 AM
Surprisingly enough my daily trip is almost the identical distance, and I drive an Insight, but it is a CVT.
I can usually get a little over 70 MPG on the route I drive regularly.
It's very close to the same percentage.
The difference is I don't employ any of the more difficult hypermiling techniques, and the car is unmodified.
regards
Mech
07-08-2010, 07:39 AM
I've found its pretty easy for me to consistently hit 30% above EPA in automatic transmission vehicles, and higher in manual trans vehicles. This has been consistent amongst a bunch of cars I have driven. I'd imagine if you do the same things in a different vehicle your % will stay relatively the same.
Do note that hybrids (see my sig) are a different story.
07-08-2010, 08:00 AM
Hypermiling rookie
like "daox" said,
hybrids are a different story
because as they come out of the factory they are mechanically & aerodynamically enhanced for FE which means IMHO it would take more effort and innovation to improve the MPG figures over the ones measured by EPA for example. Things like regenerative braking, start/stop , use of electric motor at low speeds help keep the FE high, whilst when driving a regular car using hypermiling techniques there's more things to improve simply because "regular driving" is bad for FE.
Just my 2¢
07-08-2010, 10:07 AM
This is the year
Bug - '06 Volkswagen Beetle TDI PKG1 90 day: 37.04 mpg (US) F-350 - '11 Ford F-350 Lariat 90 day: 16.23 mpg (US)
Just as a comparison I have an '04 F-150 that I easily obtain 20% higher MPG than their suggested values.
07-08-2010, 10:45 AM
Hypermiler
I agree with the others. The higher the factory rating, the harder it will be to beat that rating. For a fairly similar car, though, you should perform similarly. If you drove a Corolla, for instance, I'd expect you to see the same 50-55 mpg.
The best hypermiler I know of in an MT Insight (1) is getting ~115 mpg averages these days. That's 116% above the (new) epa combined. I, driving similarly to what he does, can get ~150% above (new) epa in my civic.
07-08-2010, 12:16 PM
Smeghead
ok thanks that is kind of what I thought. I had figured most hybreds make their gains by smoothing out driving style much the same as hypermiling technique do.
07-08-2010, 05:03 PM
eco....something or other
I would LOVE to have a MT Insight!!!! WOW!!
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
07-09-2010, 12:37 PM
#9 (permalink)
I think newer vehicles would be harder to beat the EPA by the same percentage. Because of old EPA numbers. And because newer vehicles usually have more enhancements for better mpg, whether it be aero or engine tuning. Newer vehicles are usually more controlled and you can't mess with it's brain as much to persuade it to change shift points, etc.
Winter daily driver, parked most days right now
Summer daily driver
07-11-2010, 11:55 AM
#10 (permalink)
i dont know about u but the terrain is my biggest faul.
i dont see why u couldnt get the same, if the technology is the same.
my old tacom 4x4 i could 24 mpg with out trying hard, buyt my 81 carbed i cant harldy get over 21mpg , both were rated the same well close.
