Old 04-29-2020, 09:27 PM   #41 (permalink)
Dirty deeds done with sheep.
The Following 2 Users Say Thank You to oil pan 4 For This Useful Post:
redpoint5 (04-29-2020), thingstodo (05-01-2020)
Old 04-29-2020, 11:41 PM   #42 (permalink)
I thought the best motor for a tractor conversion would be a forklift motor.
Considering that forklifts are seen as more related to a tractor than to a car or truck in my country, that makes sense. On a sidenote, since the Renault-Nissan alliance was trying to focus on a wide array of applications for the very same basic drivetrain of the Leaf to the point of having fitted it even to a truck, it wouldn't be so surprising to see some newer forklifts also resorting to that motor instead of the KA24 engine...
Old 04-30-2020, 03:27 AM   #43 (permalink)
In the US electric Toyota forklifts have been using AC motors for at least 5 years now. But they are sill using lead acid at 36v.
Old 04-30-2020, 05:54 PM   #44 (permalink)
Since the lower the voltage the larger a motor usually is in order to develop the same power, that's not so pointless at all since it will allow to use less ballast weight.
Old 05-01-2020, 09:58 AM   #45 (permalink)
It's a custom forklift only FLA, having a mix of chemicals in the plates. Forklift batteries can be ran dead and recharged, have huge gaps under the plates for slough off. Cheap chemistry, 100% recyclable, existing compatibility with thousands of businesses.
300, conversion, electric, harvester, international, tractor, utility
