Old 08-09-2010, 02:55 AM   #1 (permalink)
My Goal: 35 MPG All Day
RandomFact314's Avatar
1NZ-FE (Year 1) - '05 Scion xA RS 2.0
Last 3: 34.02 mpg (US)
1NZ-FE (Year 2) - '05 Scion xA RS 2.0
90 day: 33.32 mpg (US)
1NZ-FE (Year 3) - '05 Scion xA RS 2.0
90 day: 35.32 mpg (US)
1NZ-FE (Year 4) - '05 Scion xA RS 2.0
90 day: 34 mpg (US)
1NZ-FE (Year 5) - '05 Scion xA RS 2.0
90 day: 26.87 mpg (US)
1NZ-FE (Years 6,7,8) - '05 Scion xA RS 2.0
90 day: 28.6 mpg (US)
1NZ-FE (Years 9,10,11) - '05 Scion xA RS 2.0
90 day: 27.8 mpg (US)
1NZ-FE (Years 12,13,14) - '05 Scion xA RS 2.0
90 day: 29.13 mpg (US)
Replace tires with skinniest tires recommended by OEM
"Replace tires with skinniest tires recommended by OEM" where can I find what the skinniest tire I can put on my 1997 accord? and which number is that in the tire size thing like "185/65/15" its the 185 that tells how skinny right?
I want to go skinnier but taller but with the same rim size. I remember having the taller rims on my neon, I LOVED adding in that extra 10% to each miles driven since they were 10% bigger
Old 08-09-2010, 05:47 AM   #2 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Skinnier tires may have reduced weight/load limit, so keep that in mind when shopping. Make sure you won't be hauling more weight than your new tires can take.
I don't know about your Accord, but my 307 already came with the skinniest OEM tire (195/65R15). But I run 185's in the winter with no problems.
Old 08-09-2010, 06:45 AM   #3 (permalink)
Tire Geek
CapriRacer's Avatar
Originally Posted by RandomFact314 View Post
"Replace tires with skinniest tires recommended by OEM" ...........
Barry's Tire Tech
Based on that, the "skinny tire" advice doesn't seem to be as important as selecting tires with LRR.
- AND -
Load carrying capacity seems to be important. Bigger (in terms of load carrying capacity) seems also to be better.
Old 08-09-2010, 01:29 PM   #4 (permalink)
90 day: 34 mpg (US)
there are some michalin radial x tires (lrr) on craigslist with the rims on them for $100, I would mount them on my accords rims (since the others are 5 lug) and use those...
Only 1 problem, they are for a Jimmy so they are way bigger than the stock accord wheels lol, thats lrr tires and can add 18% at the end of each fuel log, haha
my stock is 185/65/15, the jimmy's are 235/75/15
Old 08-09-2010, 01:58 PM   #5 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Random,
I use TIRE RACK to get my tires. they have a chart the shows the diameter and alloable width. they say the stock tire is 195/65/15 w 25inch diameter. If you just run that tire you'll improve your mileage.
235/75/15 has a 28.3inch diameter also is probably too wide for the stock rim
Kumho Ecsta ASX
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Hyperinflating tires CapriRacer Hypermiling / EcoDriver's Ed 276 03-14-2022 03:51 AM
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 01:17 PM
Tips needed for eco-driving my diesel truck! nubbzcummins Hypermiling / EcoDriver's Ed 65 12-07-2010 01:37 PM
OEM tires more efficient than same aftermarket replacement MetroMPG General Efficiency Discussion 5 03-01-2010 02:11 PM
