Old 04-23-2011, 07:33 AM   #1 (permalink)
Increased crankshaft/bearing wear with stop/start systems
Powered by Google Docs
Basically they figure stop/start systems will go through 3x the number of start cycles than regular engines, and a start cycle is a cycle the crank and bearings experience lack of pressurized lubrication.
Of course if new bearing tech doesn't fix it, an oil pressurizing system could be added.
Those of you who extensively P&G might want to consider that 3x wear thing being a possibility for you...
Old 04-23-2011, 12:03 PM   #2 (permalink)
Many cars with start stop already use an electric oil pump to reduce the load on the engine.
Old 04-23-2011, 12:15 PM   #3 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Shame that the warning comes from an advert, eh?
I don't disagree, but at the same time, I've seen plenty of really high mileage cars with no engine rebuilds on them to suspect that this is more like slick 50 and ptfe-additive oil.
Old 04-23-2011, 12:37 PM   #4 (permalink)
vtec-e's Avatar
De Yaris - '04 toyota yaris T2
90 day: 69.55 mpg (US)
I recall an article that mentioned that the crankshaft bearings etc was made of tougher stuff to hold up against the extra start/stopping. It was a while back though so don't ask me where it was!
Old 04-23-2011, 04:50 PM   #5 (permalink)
Smeghead
escort - '99 ford escort sport
90 day: 42.38 mpg (US)
scoobaru - '02 Subaru Forester s
90 day: 28.65 mpg (US)
Don't load your engine till oil pressure comes back up. Should solve most of the issue.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
Old 04-23-2011, 05:03 PM   #6 (permalink)
in tents
dennyt's Avatar
The Adventure Wagon - '94 Subaru Loyale Wagon 4x4
Subaru
90 day: 33.43 mpg (US)
Electro-Monkey - '11 Surly Karate Monkey BMC V2S Front Hub Motor
90 day: 694.1 mpg (US)
I wonder which is greater - connecting rod forces before the oil pressure comes up (very low load, just compression), or the radial load from the starter pinion gear? What I'm getting at is, would hybrid systems with electric motors coaxial with the crankshaft avoid a major component of startup wear, by eliminating the pinion gear load on the crank bearings?
A quick calculation for my car: 92mm bore = 10.3 square inches, at 170psi (last time I checked compression) that's 1750 lbs on the connecting rod. I don't have my starter motor torque & pinion diameter handy...
Old 04-23-2011, 07:13 PM   #7 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
Pulse withe E(on)c would eliminate this:0
Failing that, at £500 for a hunkajunk, I can get through 30 new(to me) cars before hitting the price of a car with start/stop
Old 04-24-2011, 12:55 AM   #8 (permalink)
vacationtime247's Avatar
The Toylet - '87 Toyota Supra 350 Chevy V8 / 700R4
In-Durrrr-Oh - '09 TMEC Enduro TMEC 200cc Enduro
90 day: 60.9 mpg (US)
Tem-poo - '86 Ford Tempo GL 4 Door 2.0 Liter Diesel 5 Speed
90 day: 47.52 mpg (US)
Ass Tick - '01 Pontiac Pontiac Aztek GT 5 Door
Green Baby Poop Stain - '01 Pontiac Aztek Aztek Base Model
Black Track - '01 Pontiac Aztek GT
Should be less of an issue with good oil and smart use. I'd venture to bet that they were not nice at all to the test engines. Testing them under a worst case scenario. When I EOC, the engine is already at operating temp. Don't accelerate hard after re-start and be smart. Mostly use it on the Escort and it was a freebie. So if something terrible happens, I'm not really out anything.
VT247
Old 04-25-2011, 09:59 AM   #9 (permalink)
I was always under the impression that the worst wear came from a "dry" start, after the engine had been off long enough to allow the oil toy drain down to the sump and reducing the remaining film too much. If you engine is only off a minute I don't believe that this is the case.
Unfortunately the engine is restarted as you are trying to accelerate with the herd away from a light. With an electric oil pump, you could give it a second or two to build some pressure or you could use an accumulator for instant pressurization, albeit with a more complex system.
Old 04-26-2011, 05:51 PM   #10 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Dry and cold - thick oil that doesn't lube as well.
