Old 12-08-2009, 11:21 AM   #71 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Yeah, I think that does sound more efficient/better/less prone to failure due to clogging etc.
Back to the PWM controller, I tried it out last night and... well there was a fairly violent electrical explosion, the biggest one I've seen from a simple 12V circuit anyway. So, I need to get a replacement mosfet and check what the heck I soldered in wrong. Powering the EGR valve up manually it doens't pull more than 1.3A, so the controller is plenty capable of handling the power requirements. I must have done something wrong at assembly.
Very cool project! Keep up the good work and hang in there.
I'm looking at doing a home built design unit for my car also. My thoughts are to run two 38mm waste gates. One to control boost, the other to act like a EGR valve. This one will be ran off my electric boost controller in my efi software. I already have a AEM electronic boost solenoid. I will have to run CO2 to use as a media to open this waste-gate under low to no boost. The other waste-gate will be activated by my manual boost controller.
Pressure Gradient Force
The Positive Side of the Number Line
Old 12-08-2009, 06:29 PM   #72 (permalink)
Gentlemen, for your amusement:
Tweaking the EGR, Part 1
Tweaking the EGR, Part 2
The Following User Says Thank You to silverinsight2 For This Useful Post:
drbobwoolery (12-08-2009)
Old 12-08-2009, 09:25 PM   #73 (permalink)
Thanks, but those were posted a while back in this thread.
Old 12-08-2009, 11:10 PM   #74 (permalink)
49state 4door - '91 Geo Metro 4 door
90 day: 59.31 mpg (US)
old blue - '91 Geo Metro base CA
I sure managed to miss them!
The Aussie mag has some remarkable articles on water injection also. Studies of using up to 1.5 times as much water as gas to operate on low octane fuel are detailed. The string of URL's is lost, but searching Autospeed will show them.
Old 12-09-2009, 07:29 AM   #75 (permalink)
Dang! busted. Guess I'll start have'n to read the whole thread.
Old 12-09-2009, 11:37 AM   #76 (permalink)
Send a message via MSN to markweatherill
I wonder if it would be beneficial to have EGR active on the overrun, that is, when deceleration fuel cut is happening.
I could expect it to increase coasting distances a bit by reducing engine braking.
Would that work?
Old 12-09-2009, 11:53 AM   #77 (permalink)
Very interesting idea Mark! Assuming you stay in gear I'd imagine it would reduce pumping losses. I have no idea how much. You are still compressing the intake charge... I'll have to keep that in mind as I go forward.
Old 12-09-2009, 02:21 PM   #78 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
I don't think EGR reduces pumping losses, because you've already pumped the exhaust out, and you're sucking in the EGR's recirculated gasses through the intake, just the same as you would be normally. It's a nice thought, I just don't feel like it's going to work that way.
Even if it did, it would be approximately in line with opening the throttle with the engine off and using the compression for braking. The difference isn't there on all vehicles, and even if it is, it's only a few feet one way or the other.
Old 12-09-2009, 03:21 PM   #79 (permalink)
EGR is routed back to the intake behind the throttle butterfly. So, you are right, it would be like opening the throttle.
Old 12-31-2009, 05:36 PM   #80 (permalink)
Andy0x1's Avatar
V - '05 Cadillac CTS-V V
Egr
Just thought I would chime in on this thread;
I have a Positive displacement Supercharged vehicle and disabled the EGR system after installing an AIR-WATER intercooler between the Supercharger and the intake manifold.
My reasoning was to keep the intercooler and valves cleaner.
I did this over 4 years ago, amung many other modifications.
I feel that this did result in a slight reduction in fuel economy however it may all be in my head as I can't quite explain why it would matter much when accounted for.
My understanding as to why:
1) Pumping loses. (minor)
Why? With the throttle at at whatever position, lets call it closed, x amount of air is metered and allowed into the intake manifold. this minor amount of air only slightly reduces the vacuum the pistons have to work against.
A functioning EGR would further reduce back-pressure, without introducing addtional oxygen effectively maintaining the air/fuel ratio and injector flow rates.
On the flip side, the reduction in vacuum also leads to increased 'windage' however minor.
2) Ignition spark / Timing Advance / Retard (moderate)
Without EGR the fresh air entering the combustion chamber when mixed with fuel will burn faster, because it is burning faster this could lead to knock / detonation. Assuming the timing is corrected for this condition (reduced) the mixture will ignite later and possibly result in more burn occuring after the power stroke and during the exhaust stroke effectively adding heat to the valves / ehaust / heads that would otherwise be.. wasted due to poor burn? (less power) but that would mean better fuel economy.
Will you see more power (WOT) with EGR disabled? I don't think so, because the EGR closes during WOT anyway.
My New 4cyl Compact Doesn't Get Good Mileage Stone Axe Introductions 13 02-08-2013 12:06 PM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Trouble Code PO401 EGR Flow Insufficient Detected Ford Man Off-Topic Tech 4 12-09-2011 12:45 PM
How to get instant fuel consumption from Megasquirt TELVM Instrumentation 11 08-29-2011 02:47 PM
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 07:38 AM
