Old 12-15-2009, 01:40 PM   #71 (permalink)
Eddles's Avatar
Eddles's Astra - '01 Vauxhall Astra ECO4
90 day: 61.03 mpg (US)
Originally Posted by Christ View Post
Do you have a holesaw that will just barely fit over the camera? That'll be the one you want to use, and then seal the camera into the mount with hot glue or silicone caulk.
Camera came with core drill included. I'm not quite too sure if I can adjust the camera using the adjustment rings on a curving surface, but hey, I can always try, can't I?
My aim: to achieve 3L/100km.
Best tank @ 65mph: 864.2 miles 69.36MPGus 3.4l/100km
Old 12-15-2009, 01:55 PM   #72 (permalink)
Maroon Ballon - '98 Chrysler Town & Country LXI
90 day: 26.42 mpg (US)
MaEsTRO - '95 Geo Metro 5spd hatch, 3 cyl
That's nice that it came with a bit. With such a wide angle of view, aiming the cam shouldn't be that critical, just not too far in any one direction. What I would do is to hook up the camera to the monitor and then place the camera where you want it and use masking tape and packing material or cardboard or whatever to aim the camera exactly where you want it. Then put your shark fin mount next to it in order to see where you need to put the mounting hole in order to keep the camera aimed where it is. If you can do this then once you get it mounted permanently, you should be able to fine tune the aiming as Neil says with the rings.
Old 12-15-2009, 04:18 PM   #73 (permalink)
Hi,
I would suggest a temporary installation first before you fine tune the fin. You could just tape it down to the roof (sitting on a small wedge/shim) to check how it works, what you can see, etc.
EcoModder iPhone/iPod Touch Theme! SVOboy Forum News & Feedback 1 08-12-2008 10:58 PM
