Old 02-28-2010, 05:15 PM   #11 (permalink)
Originally Posted by captainslug View Post
It's also NOT a hybrid. A hydrostatic drive system is a type of transmission. Albeit an extremely efficient one, but that doesn't make it a hybrid because it's only propelled by a single energy source: the diesel engine.
Having a method of storing the hydraulic pressure is no different than having it stored in a flywheel.
Or a battery.
Or a spring
Or a tank of hot air
Or pushing a rock up the side of a mountain
regards
Mech
Old 03-03-2010, 06:38 PM   #12 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
Originally Posted by RobertSmalls View Post
The BSFC map in the Wiki is for the CVT variant, which doesn't do lean burn. There's a BSFC map for the 5mt here: http://ecomodder.com/forum/showthrea...iki-12355.html
but it doesn't appear to have lean burn either.
Somewhere near the bottom of my Insight to-do list is to buy some dyno time and try to measure lean burn BSFC.
The lean burn version is already in the wiki at it's at ~40% efficiency give or take. To edit the wiki just click on the edit tab (top of the page) and follow the formatting of the other entries.
Old 03-03-2010, 11:48 PM   #13 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
But the other entries have a [image:foo.jpg] entry, and I can't find the button for uploading a .jpg to be embedded in the wiki.
Old 03-04-2010, 12:05 AM   #14 (permalink)
roflwaffle's Avatar
Just use the one you uploaded in the post you linked earlier, Insight5mtBSFC.jpg or whatever it was called.
Are hybrid SUVs a good or bad thing? SVOboy Hybrids 71 05-05-2017 04:24 PM
Hydraulic Hybrid Vs. Electric Hybrid jason.thompson EcoModding Central 20 09-15-2009 08:39 PM
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 11:45 AM
Milwaukee Hybrid Group Meet 3-28-09 Daox Events & Meet-ups 1 03-28-2009 10:04 PM
Honda Begins Use of Class 8 Hybrid Truck Q1000 Hybrids 0 03-11-2009 08:55 PM
