Old 09-15-2010, 03:21 AM   #1 (permalink)
meelis11's Avatar
Green frog - '97 Audi A4 Avant 1.9TDI 81kW
Diesel
90 day: 43.1 mpg (US)
MPGuino and Coolant temp sensor signal
Hi,
I would like to see coolant temperature on MPGuino but I dont know how to connect it to MPGuino.
Has anybody done it? Schematic/sketch would be nice
I know that coolant temperature sensor varies resistance and ecu sends 5V into it.
I measured it some time ago, some example measures:
* outside temp 18C, engine not started = 2960 ohms.
* warm engine (ca. 90C) = 170 ohms
* 4 hours later 1325 ohms
Old 09-15-2010, 07:18 AM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Can you measure the voltage on the sensor? It is probably part of a voltage divider circuit, and if it is putting out in the range of 0-5 volts then it is suitable to be read by an atmega without extra circuitry.
The next problem of course is adding some code to read it and display it.
Old 09-15-2010, 07:58 AM   #3 (permalink)
meelis11's Avatar
Diesel
I think it is powered with 5V but I better measure it.
So if it is 0-5V then I can just attach wire to sensor wire and other end to ATmega pin?
Old 09-15-2010, 08:09 AM   #4 (permalink)
dcb
needs more cowbell
dcb's Avatar
That's the idea. Of course no guarantees, but atmegas are only a couple bucks.
Old 09-15-2010, 01:06 PM   #5 (permalink)
NightKnight
NachtRitter's Avatar
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 54.39 mpg (US)
Mathilde - '99 Volkswagen Eurovan Camper
90 day: 16.87 mpg (US)
Similar setup in my VX; Interested in doing the same thing. I can do a direct connect, but anything outside of that is a mystifying to me.
Old 09-15-2010, 01:11 PM   #6 (permalink)
dcb
needs more cowbell
dcb's Avatar
I mapped out a map sensor connected to an atmega over here, fyi
http://ecomodder.com/forum/showthrea...nsor-5208.html
might be more useful than temp, or offer some thoughts on temp anyway.
The Following User Says Thank You to dcb For This Useful Post:
NachtRitter (09-15-2010)
Old 09-15-2010, 01:20 PM   #7 (permalink)
NightKnight
Diesel
Interesting, and thank you
