Old 02-10-2009, 01:19 AM   #1 (permalink)
GEOrge - The Thoroughbred of Righteousness - '95 Geo Metro
90 day: 34.13 mpg (US)
Installing in metro, injector issue?
Hi folks,
I'm getting ready to put together and install the mpguino spiffie kit in my '95 4 door 4 cylinder geo metro.
In my research I've run into a few posts mentioning some sort of issue with hooking up the fuel injector at the end with the ECU on a metro, I couldn't find any detail about this in my searching, so now I'm asking before I start tearing it apart.
My question is this, Is there an issue? do I have to take wiring through the firewall and tap the injector, or can I get away with making it much simpler, and bring all the wiring to the ECU?
Thanks,
Ben
Old 02-10-2009, 02:15 AM   #2 (permalink)
nut
Coyote X's Avatar
Metro XFi - '93 Geo Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 Suzuki DR650SE
90 day: 55.26 mpg (US)
Send a message via MSN to Coyote X
The ecu is a pain to get at under the dash. If you can get to it then it is fine to hook up there. I think most people would rather just run a wire out and hook up under the hood. It is a lot easier
Either way works fine though.
Old 02-16-2009, 09:17 PM   #3 (permalink)
americasfuture2k's Avatar
SLOLANE - '08 Chevy (Daewoo) Aveo5 SV
90 day: 30.55 mpg (US)
not a metro, but an aveo
i gathered everything i needed to start digging into the ecm connectors to grab the vss and inj low wires. got to the car and saw how much if a PIA it would be and decided going after the end source would be much much easier. took me a lot less time to get the correct wires that way than is would have digging through the ECM wire bundle.
If you cant fix it with a hammer, then you have an electrical problem
http://www.cardomain.com/ride/3159589
shutup, im working on it
Old 02-17-2009, 12:41 AM   #4 (permalink)
Thanks for the help guys! I guess I'll take a look at the ecu, and then decide...
Unfortunately though, I ran my Metro into a tree, so assembling and installing the MPGuino , will have to be delayed further, until I can put the front end back together, and have a drivable vehicle...
Thanks!
Geo Metro convertible / Kubota diesel engine conversion (driving!) kimer6 EcoModding Central 118 07-01-2013 04:21 PM
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 05:11 PM
Saved a Geo Metro and saved big $ (stopped driving my pickup) Johnny Mullet Success Stories 24 05-08-2010 12:15 AM
Planning Project Eco-Z seanof30306 EcoModding Central 20 08-24-2009 10:00 PM
Metro Hoarding 101 - also: Metro pickup trucks! Cowspots Introductions 28 04-14-2008 07:26 PM
