03-16-2015, 09:09 PM
#1471 (permalink)
You're right. Sort of a Midnight Blue. I was looking for 911 style headlights.
Edit: Needs more pictures. Here's the 1941 Horch 853 Sportcabriolet, from Guns, Oil, & Dirt.
03-17-2015, 03:22 AM
#1472 (permalink)
Originally Posted by kach22i
I think the note was for the 944 Turbo "S"....hood up, white sign in front of it.
Also known as a 951.
The "Turbo S" was introduced as an option for the 1988 model year, and then in 1989 the "S" was dropped but all of the 944 Turbos were the same spec as the "S" had been. I think the Turbo may have stopped being imported after that? I forget...
There was also a regular 944S, introduced somewhat earlier. And a 944S2, which I believe was the 16-valve model.
-soD
The Following User Says Thank You to some_other_dave For This Useful Post:
03-17-2015, 03:25 AM
#1473 (permalink)
That Horch is wild.
03-17-2015, 01:11 PM
#1474 (permalink)
That was the only picture I'd seen; but I got to wondering about that thing that looks like a grille flipped up on the front so I went looking.
This Is a Fire Truck - Neatorama
I suspect there is an engine-driven water pump under there. There is a hose bib right above the license plate.
03-18-2015, 02:01 AM
#1475 (permalink)
Gives a new meaning to greenhouse.
03-18-2015, 10:25 PM
#1476 (permalink)
03-18-2015, 11:35 PM
#1477 (permalink)
03-18-2015, 11:53 PM
#1478 (permalink)
Wow, what a swoopfest! Too bad it ain't aero.
The Following 2 Users Say Thank You to Frank Lee For This Useful Post:
03-19-2015, 12:46 AM
#1479 (permalink)
aero enthusiast
Dang, i say page 148 for best in thread! Them some smooooth looking rides.
03-19-2015, 10:41 AM
#1480 (permalink)
It's got good fineness ratio, taper in plan, dual base pressure plates, headlights that follow the Template curve... ??
Fine, then:
http://forums.vwvortex.com/showthread.php?7047579-This-is-the-pre-war-luxury-car-appreciation-thread&p=87264128&viewfull=1#post87264128
