06-18-2012, 07:21 PM
#381 (permalink)
V12
Great catch, Phil. A 4-cylinder mid engine vs the 2-cylinder front engine of the LM64. The Matra had a midengine V12!
I'll bet that puppy had a sweet note! I used to sell flowers on street corners for a buck an hour in Woodland Hills,Calif,when in junior high school.Every once in awhile,a Maserati would drive by with that 12-cyl sound.They could really go.'bet the Matras was a riot!
06-20-2012, 06:15 PM
#382 (permalink)
06-20-2012, 06:19 PM
#383 (permalink)
06-20-2012, 06:24 PM
#384 (permalink)
06-20-2012, 06:45 PM
#385 (permalink)
1st 'minivan'
Originally Posted by kach22i
AutoWeek or Automobile magazine referred to the Stout Scarab as the world's first minivan.Really nice shots,thanks!
06-21-2012, 08:04 AM
#386 (permalink)
Master Ecomadman
- Tony
06-21-2012, 08:28 AM
#387 (permalink)
The Stout Scarab doesn't fit the template, but then the rear engine and cooling exhaust is unconventional, so obviously it has better aero drag than most cars.
The piece of history that we are dancing around is that the mid 30's is when paved highways were becoming more common, which makes it obvious that aerodynamic drag is a very important issue.
The two "solutions" to high drag is either streamlining or a bigger engine -- elegant design or brute force. We need elegant design for efficiency.
06-21-2012, 09:31 AM
#388 (permalink)
The Stout Scarab doesn't fit the template..........
That is my thinking too, but also consider that in "plan view" it fits better than most car's side profiles.
06-23-2012, 12:01 AM
#389 (permalink)
The Following 3 Users Say Thank You to some_other_dave For This Useful Post:
06-23-2012, 08:53 AM
#390 (permalink)
Originally Posted by some_other_dave
Alfa Romeo tipo 163D
Some images of a crude scale model:
1941 AR tipo 163 16C 7 Sc43 | Flickr - Photo Sharing!
Some better ones of the same model: [ 1941 ] Alfa Romeo Tipo 163 16C Prototipo Berlinetta ( 1/43 ) | Alfa Romeo Modelcar Museum
Another - single view this time:
Prewar
At all angles and details I have concluded; the front wheel coverings must be able to pivot and turn with the front wheels, otherwise this car can only run in a straight line.
In addition, I suspect the front radiator must discharge under the car, because I see no other vents, and with the front wheels block venting through the wheels wells (how the current 911/Boxster does it).
