Old 05-26-2016, 06:15 PM   #1 (permalink)
Geoff - 5 speed swap - '02 Volkswagen Jetta GLS TDI
Diesel
Team Turbocharged!
90 day: 49.46 mpg (US)
Fusing Titanium - '19 Ford Fusion Titanium
Team Ford
90 day: 50.91 mpg (US)
New tire question
Looking at new tires for my car.
The tires I'm looking at are these....
Continental*PureContact with EcoPlus Technology
The question I have is, what do you think would be the better option. 205 50r17, which will be a little narrower but also shorter, or 215 55r17, which will be slightly wider, but will lower RPM because it is taller
2002 Jetta GLS TDI 345k+ miles, all mods listed in description 156HP, 298FT/LB
The eclipse has retired, but I still like seeing it around
Old 05-26-2016, 07:41 PM   #2 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
how much time do you spend at 'cruising'?
how much time in stop and go?
taller is better in my opinion
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 05-26-2016, 09:46 PM   #3 (permalink)
Taller is usually better.
Old 05-26-2016, 09:51 PM   #4 (permalink)
Diesel
Team Turbocharged!
Team Ford
Most of my drive is cruising, on top of plenty of road trips
Old 05-26-2016, 11:49 PM   #5 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Then you go taller, for gearing advantage. The extra rotational mass will matter less in cruising than it does in stop/go at lower speeds.
mcrews (05-27-2016)
Old 05-27-2016, 11:24 AM   #6 (permalink)
mcrews's Avatar
this^^^^^^
ECO MODS PERFORMED:
First: ScangaugeII
Old 05-27-2016, 03:41 PM   #7 (permalink)
Diesel
Team Turbocharged!
Team Ford
Thanks everyone. I ended up going with a different tire all together after reading the reviews. Should still be one designed for better fuel economy, and also 205 55r17. Best of both worlds in my opinion
The Following User Says Thank You to Rango318 For This Useful Post:
mcrews (05-27-2016)
