Old 09-25-2008, 06:56 PM   #1 (permalink)
Tracy - '00 vauxhall corsa
internal replacement mirrors ?
so the most successfull mod i've done so far has been to take off the passenger mirror and i am now eyeing up the drivers mirror. does anyone have experience with internal mirror replacement mirrors? not cameras.
i was thinking about motorcycle style mirrors cut short and threaded so that they can be bolted into a socket from the old mirror.
what is the view like from inside mirrors?
NEW UNIVERSAL CLAMP ON MIRRORS MOTORCYCLE on eBay, also Lighting Mirrors, Accessories, Motorcycle Parts Accessories, Cars, Parts Vehicles (end time 14-Oct-08 19:51:38 BST)
Nissan Leaf 24kwh. Average FE = 300mpg 3.6miles/kwh (@plug)
Old 09-25-2008, 08:25 PM   #2 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
modmonster -
I did just that. I need to take some pix. I will get back to you in a bit.
CarloSW2
American Solar Energy Society
Old 09-26-2008, 02:50 AM   #3 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
modmonster -
Ok, here is what I have :
MIRRORS WITH SLIDE-ADJUSTABLE HEADS - TINTED GLASS : JC Whitney: Motorcycle Parts & Accessories - $18 a pair
I like mine because they are on a sliding stalk and the stalk is short. This gives me flexibility in moving it into position.
Problems: The "range of vision" if very narrow inside the car. It only shows cars that are right in my blind spot. The vertically mounted rectangular convex mirror actually gives me more stuff to see. I get past this by having a 17" wide convex rear view mirror :
http://ecomodder.com/forum/13401-post9.html
The rear view mirror is my "rear view HQ", and I use my side mirrors for verification.
Fix: I think I will stick a big convex mirror onto the flat internal side mirror :
CIPA Stick-On HotSpots Convex Safety Mirror
I do miss my original outside mirror at night. If the traffic is heavy, it's a bit nerve-wracking to change lanes.
CarloSW2
Old 09-26-2008, 06:10 AM   #4 (permalink)
why do you have the bicycle mirror out-side? that defeats the object of the exersize doesn't it?
Old 09-26-2008, 09:56 AM   #5 (permalink)
Inside mirrors
The civic side mirrors came off easy, and actually left a bolt to mount the bracket to.
These were taken last spring so the windows and car's a bit dirty.
I like them very much,
altho I can't put a number on the savings,
but the views are exactly what I want.
Just the next lane over, the middle mirror shows what is behind.
This is the drivers view (along with some sun glare):
The door is open to see the mirror better:
This is looking at the back or the mirror with the bracket and mount:
The outside has been covered with a piece of plastic cut to fit the original opening for the mirror, while the inside has just been black-duct-taped over.
Last edited by Sandy; 09-26-2008 at 09:59 AM.. Reason: speling erors, covering comments
Old 09-26-2008, 10:40 AM   #6 (permalink)
08 xB - '08 Scion xB
90 day: 35.5 mpg (US)
I think removing the driver's side mirror is illegal in every state.
Old 09-26-2008, 11:20 AM   #7 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
modmonster -
Just like jthistle said, a driver's side view mirror is required by law in California. Even if I could get away with it legally, I would put one there to reduce the cop/hastle factor. Sandy's solution looks very clean. It looks like a convex mirror, which is what I think you need.
CarloSW2
Old 09-26-2008, 12:02 PM   #8 (permalink)
It is a convex mirror,
and in NH there are two conflicting statutes.
One says the stock mirror must be used,
and another says that the mirror must see back 200 feet,
but doesn't say it has to be stock.
I know I could get stopped for this,
but I've had cops behind me, and have seen the car and no warnings yet.
I am looking to cut down the stock drivers side mirror enclosure to hold just the convex mirror. Very narrow and aero. But outside and legal looking.
Old 09-28-2008, 02:09 PM   #9 (permalink)
for imports (potential rice rockets) you should consider aftermarket mirrors.
look for "spoon" replicas, usually around 50 for a set of 2, they have a very small area of mirror and are significantly smaller than stock mirrors.
ricers are concerned with reducing drag too, so you should spend some time on their websites... ill see if i can find some quality examples
Internal hub 3 speed? Tony Raine Alternative Transportation 20 11-08-2010 10:55 PM
CA Vehicle Code - Mirrors thebrad Aerodynamics 2 08-30-2008 11:03 PM
Currently hot: Replacement Hybrid Battery Costs Plummet (Dugg!) MetroMPG EcoModder Blog Discussion 3 06-09-2008 12:39 AM
Bicycle side view mirrors? cfg83 Aerodynamics 2 02-15-2008 11:54 AM
Video: Ditching the Side Mirrors Increases Fuel Economy Peakster Aerodynamics 6 12-05-2007 07:43 PM
