Old 10-19-2020, 10:44 AM   #51 (permalink)
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Originally Posted by Vman455 View Post
Thanks, MetroMPG. And my sincerest apologies for any egging on I did; sometimes it was hard not to jump in.
On that note, if anyone wants to try the Scanivalve pressure sensors I have a couple left to give away.
What do these sensors look like? I may throw one in the PCV Valve circuit to measure the blow by changes on the prius. Just bought a volvo oil trap to throw in too.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
Old 10-19-2020, 08:08 PM   #52 (permalink)
Dark Egg - '12 VW Touraeg
We dont really know how gravity works. Often the more we know about something will show the less we really know about something.
The Following User Says Thank You to Hersbird For This Useful Post:
Fat Charlie (10-19-2020)
Old 10-19-2020, 09:13 PM   #53 (permalink)
90 day: 29.78 mpg (US)
Knowledge only brings more questions.
The Following 2 Users Say Thank You to redpoint5 For This Useful Post:
Fat Charlie (10-19-2020), Hersbird (10-20-2020)
Old 10-19-2020, 09:36 PM   #54 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
These are really small, only 1.27 mm height. Useful for measuring panel pressures; if you're trying to get pressure in a tube or line it's probably easier to just stick a tube end on it.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
hayden55 (10-20-2020)
Old 10-19-2020, 11:12 PM   #55 (permalink)
Moderator
Vman455's Avatar
Yes, we do know how it works: gravity acts as an inverse-square, conservative vector field proportional to the mass of two objects. What we don't know is why it exists, but that doesn't hinder our understanding of its functioning, which we have figured out over hundreds of years of observation and mathematical reasoning well enough to launch objects to other planets with incredible accuracy.
Aerodynamics is a more nascent field than gravitational physics, and there's a lot left to figure out. Many formulae in textbooks are explicitly identified as empirical. For example,
cD = cD0 + k(cL^2)
It isn't an exact formula; the constant k has to be measured experimentally for any given car. But there seems to exist some relationship between lift and drag given generally by the formula, derived from the observation that most cars achieve their lowest drag when lift is zero or close to zero.
At the same time, that's what appeals to me--we haven't figured it all out yet. There are phenomena which remain to be discovered.
Old 10-20-2020, 02:00 PM   #56 (permalink)
cD = cD0 + k(cL^2)
That's how we thought it worked, but it's proving to not exactly follow that. Plus that may be the reaction you can observe but we still dont know HOW or I guess as you put it WHY. Personally I think why is more of a philosophical question, and you are really saying we dont know how it works.
Fat Charlie (10-20-2020)
Old 10-20-2020, 02:32 PM   #57 (permalink)
Does the fact that pi is an irrational number tell you that physical reality does not employ the Cartesian Coordinate system. Still trying to work that out.
Old 10-20-2020, 03:38 PM   #58 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
I hadn't seen this thread prior to just now, but I thought I'd chip in my 2 cents:
I'd hate to lose either of them. I believe it's worth noting, however, that I observed Julian move to Ecomodder after being banned on Insight Central. Which is not to say I'm laying fault or blame, with either of them. Strong personalities though.
RedDevil (10-20-2020)
Old 10-20-2020, 03:52 PM   #59 (permalink)
Tomorrow [it] will have been one week. I've made my prediction.
I thought about PM'ing the both of them, but they wouldn't see it unless they have email notifications turned on.
Old 10-20-2020, 03:58 PM   #60 (permalink)
Aerohead probably didn’t notice the ban considering his internet days are Wednesdays.
Fat Charlie (10-20-2020), freebeard (10-20-2020)
