Old 09-16-2013, 08:01 AM   #91 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
Originally Posted by Arragonis View Post
What happened to the Golf, did it finally expire ?
No mod plans yet - getting Mr Audi to fix some rust (12 year warranty apparently then maybe some aero. Tyres are up high-ish at the moment.
The golf was slow and NO FUN, the e30 is slow and LOTS OF FUN
the golf got scrapped, the payment covered the tax on the 320i.
A wise move re getting it bodily spot on prior to starting tomfoolery
on the tyres front, I'd be inclined to move to 17" wheels- the additional sidewall gives a much better rid on the pothole ridden roads
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
Old 09-16-2013, 09:43 AM   #92 (permalink)
The PRC.
Had to replace 2 of the 19s so wheel changes will have to wait, plus it is the S-Line version so it has rock hard suspension anyway.
It does "waft" well though...
Old 09-16-2013, 10:03 AM   #93 (permalink)
Team m8
17" at the front, 19" at the rear
waft is where it's at for commuting. even the 320 now turns just shy of 2750 at 60mph- much better than previous
Old 09-16-2013, 10:07 AM   #94 (permalink)
The PRC.
Under 2K at 60
Old 09-16-2013, 10:08 AM   #95 (permalink)
The PRC.
Also avoided Team M8 so far as I'll drop it's average quite a bit...
Old 09-16-2013, 10:53 AM   #96 (permalink)
Team m8
I imagine my 320 will kill the average too- we should clear it out and just have the audi/pious and the 320/clio
starting from a lower base= higher potential for gain!
Old 09-18-2013, 03:46 AM   #97 (permalink)
Wheel changes also require extra care about brake clearances.
Old 09-18-2013, 08:55 AM   #98 (permalink)
The PRC.
I believe some A6s run on 17s with taller tyres, maybe not the V6s though. Wheels will be staying, can't afford new ones
Old 09-18-2013, 09:59 AM   #99 (permalink)
Team m8
use manmaths to offset cost of wheels vs ability to save fuel with uber LRR tyres that you can only get in 17", dear.
Old 09-19-2013, 03:55 PM   #100 (permalink)
The PRC.
I just bought a super laptop on this basis (I can get so much more done in a day...) so I don't think I can stretch it that far, plus my new tyres are RainSports which means I grip when others fail So they stay !
To be honest those aren't the main barriers to FE - the transmission is. The "Tipchronic" auto is a PITA. It means at lower speeds I don't have the flexibility to swap to a higher gear apart from as above and the process of shutting off at lights means the guy behind gets a flash of my reversing lights - twice, which sometimes can be worrying for them.
