Old 08-28-2013, 06:28 PM   #1 (permalink)
101Volts's Avatar
Woody - '90 Mercury Grand Marquis Wagon LS
Last 3: 19.57 mpg (US)
Brick - '99 Chevrolet K2500 Suburban LS
Last 3: 12.94 mpg (US)
M. C. - '01 Chevrolet Impala Base
90 day: 18.73 mpg (US)
R. J. - '05 Ford Explorer 4wd
90 day: 16.66 mpg (US)
Scangauge II stats going wonky in 2000 Dodge Caravan, Please help
Lately maybe due to not filling up and re-calibrating the SG2 much in the last several months the gauge started reading strange things in the "Tank" "Today" and "Previous Day" Meters; Sometimes I'll get readings like "17xx gallons used" and "$5,0xx cost" And see "2.3 MPG". Do you have any ideas why it's doing this? It also effected the Fill-up menu; I was going to calibrate the SG2 today when the van was filled up but I couldn't as the SG2 thought we went through 1,789 gallons or some high number since the last fill-up which isn't true; I calibrated it at the last fill-up.
Old 08-29-2013, 10:43 AM   #2 (permalink)
90 day: 51.82 mpg (US)
Sounds glitchy. I'd contact the company - they're good at customer service:
Contact Us : Linear Logic - Home of the ScanGauge
101Volts (08-29-2013)
Old 09-02-2013, 11:43 AM   #3 (permalink)
101Volts's Avatar
Thanks for that suggestion, I used the contact us screen just a minute or so before editing this reply.
Here are some stats from the most recent wonky readings:
Current:
2.6 MPG
1382 Gallons
317 FWT Max
$4908 Cost
-2763 miles (Yes, Minus.)
C785 RPM Max (Yes, C as in Charlie.)
23.8 Hours
124 MPH Max
156 MPH Avg (?)
Today - Same as current
Previous day; Same as current except for:
2.7 MPG
1 MPH AVG
Tank: same as Current except:
0.0 Gallons to Empty
0.0 Miles to Empty
I realize it might be good to contact the company, I thought I'd leave this here for reference. Another note is that my Father occasionally drives the van down to the garage (He has his reasons), Anyway - The point is the van is sometimes turned on for less than a minute and then is turned off so perhaps this is messing with the SG2.
Old 09-02-2013, 12:21 PM   #4 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
What is the version of your ScanGauge?
The Following User Says Thank You to t vago For This Useful Post:
101Volts (09-02-2013)
Old 09-02-2013, 07:24 PM   #5 (permalink)
101Volts's Avatar
Originally Posted by t vago View Post
what is the version of your scangauge?
4.06
Old 09-03-2013, 12:58 AM   #6 (permalink)
MPGuino Supporter
t vago's Avatar
4.06? Linear Logic lists 4.02 as their most recent version. Perhaps you got a buggy beta version of the latest version?
Old 09-14-2013, 12:17 AM   #7 (permalink)
101Volts's Avatar
Has that page been updated lately? I found 4.06 in Google:
https://www.google.com/search?q=scan...ient=firefox-a
Old 09-14-2013, 11:10 AM   #8 (permalink)
101Volts's Avatar
I sent a few emails and will be checking for a response.
Old 09-17-2013, 06:28 PM   #9 (permalink)
101Volts's Avatar
I had a response and the advice was to try resetting the ScanGauge II. I did that today and so far it seems to have helped at least, The "Tank" Screen operated well the last time I checked it. However, The "Previous Day" Screen was still off a bit.
Old 09-18-2013, 07:21 PM   #10 (permalink)
101Volts's Avatar
Since I reset the SG2 it was working properly as of the last time I checked it, Though it isn't calibrated. The Tank, Today and Previous Day screens weren't showing "2.x MPG" and other odd things the last time I checked. Perhaps it'll stay that way for a while or perhaps not.
scangauge 2, scangauge ii, troubleshooting
