Old 10-08-2010, 09:23 PM   #21 (permalink)
New springs in the injectors will probably bring the break off pressure from 13-1500 PSI up to 1800 PSI which is probably new specs. If you cant find them but have access to a tester, then shim the injectors to get the max pressure as specified. Run some Red LIne through them after you get the pressures up to specs, and the smoking will drop dramatically and your mileage will improve significantly with optimal fuel atomization.
Specs quoted are for the 83 MB diesels, but they are probably close to the same.
Also check to make sure the throttle control allows WOT, if it has a butterfly. MB went throttle less in 1982, but before that a 240 D with a maladjusted throttle linkage was the slowest car I ever drove in my life.
regards
Mech
Old 10-08-2010, 11:29 PM   #22 (permalink)
Smeghead
escort - '99 ford escort sport
90 day: 42.38 mpg (US)
scoobaru - '02 Subaru Forester s
90 day: 28.65 mpg (US)
You guys rock with the info. Oilburner is a NA diesel.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
Spark ignition Diesel engine, AKA your car mechman600 EcoModding Central 28 05-11-2017 07:12 PM
97-99.0 VW Golf / Jetta Diesel, good cars? canhonkey General Efficiency Discussion 5 01-24-2013 10:17 PM
1951 Diesel Beetle ~~~ 40MPG Laurentiu The Lounge 3 07-23-2010 04:43 PM
The First Three Diesel Passenger Cars Laurentiu The Lounge 0 07-03-2010 09:40 AM
2009 Diesel Jetta Blue07CivicEX General Efficiency Discussion 18 01-28-2009 10:16 PM
