Old 06-01-2023, 04:05 PM   #11 (permalink)
On my CRX, there was a natural variability of between 36-mpg, and 82-mpg, depending on 'routes' and 'weather', and this was without any changes to the car after modifying.
Just shooting from the hip, even if you completely blocked off the radiator, it's unlikely that you'd realize anything beyond a 3.5% mpg improvement. That would be at a steady 70-mph.
A natural variability between 36mpg and 82mpg, weather and route dependent, is a pretty bold statement. If you were to drive during a cold day like anyone normally would, and then during warm weather, one of your routes was entirely downhill and all you did was idle in neutral and coast for the entire route, yeah maybe.
If I only get 3% out of this grill block, I’m ok with that. 3% of 42mpg, which is a somewhat conservative figure during the summer for me, would be a 1.26mpg increase. Since this grill block off has only costed me about $3.50 (mostly because I want a long 10mm bolt to relocate my license plate, which isn’t totally necessary but I like the clean look and that it serves to block off as well), I would travel about 14 miles further per tank (11 gallon fill up) and save about $1.10 per fill up. Not much, but it’s the first aero mod I’ve done, still only costed me $3.50, it was fun to do, and I personally like the new look of the bumper better. It has a pretty clean look to it in my opinion.
I’ll post some pics soon. I think you’re right that I shouldn’t expect too much, but it also didn’t require much.
Old 06-01-2023, 04:21 PM   #12 (permalink)
With all else equal you could probably obtain most of that with just load, and 'the nut behind the wheel'.
The older I get, the better I was -- John Fogerty on Joe Rogan
Old 06-01-2023, 06:21 PM   #13 (permalink)
Ha, ‘the nut behind the wheel.’ I like it. Could be.
Here are some pics. Hope they work.
Wow, I don’t seem smart enough to be able to figure out how to post more than one photo in a post. Will post again with ‘after’ pic. Been a long time since I’ve done this.
Old 06-01-2023, 06:24 PM   #14 (permalink)
ID:	33854. Close up of side thingies.
Ugh. The pics are so small. Might as well not be there. Maybe different on a computer, but on my iPhone, clicking on them doesn’t do any better. If you all can see it ok, let me know. No real testing done so far.
Old 06-01-2023, 06:59 PM   #15 (permalink)
Works on this computer at this time. Weird that the yellow bar at the top is missing.
Moments ago on Main Street I followed a Jeep. The spare tire cover said "I'm the black Jeep of the family".
Old 06-02-2023, 09:43 AM   #16 (permalink)
Black jeep comment on spare cover seems to be a thing here in reno, almost like installed dealer equipment.
freebeard (06-02-2023)
Old 06-03-2023, 04:04 PM   #17 (permalink)
So to follow up, I do not think the block off for me is giving consistent results. On a tank that was my daily commute I got 14.5 which is country and city roads and also got one slightly higher at like 16 with a normalish commute. I also took it off on Friday and during a mostly country miles got 18 which is the second highest I have ever gotten and I think the increase I have seen lately is the bug deflector. So I am convinced that 20mpg was legit, just everything was perfect somehow. I might try more experimenting when I get back from MI despite not seeing any real temp raise whether its blocked or not, I do not want to risk blowing this radiator before my sand dune trip.
The Following 2 Users Say Thank You to XCRN For This Useful Post:
aerohead (06-05-2023), freebeard (06-03-2023)
